ALL THOSE PEOPLE OUT THERE SUFFERRING FROM THIS. THERE IS AN SIMPLEST SOLUTION AND THAT IS JUST DOWNLOAD ACER LAUNCH MANAGER VERSION 8 FROM GOOGLE. https://softfamous.com/acer-launchmanager/ THIS IS THE LINK AND INSTALL THIS AND BLUETOOTH ICON WILL APPEAR IN THE TASK BAR. IT WAS SO SIMPLE PLEASE TRY THIS
SOURCE: bluetooth and IRda in Acer aspire 5320
Click the Start button , click Control Panel, click Printers, and then click Bluetooth Devices. Nearby devices are listed on the Devices tab. First, you must have another Bluetooth device near you, it will not activate alone.
SOURCE: acer aspire 5335 no bluetooth? XP
go to control panel then find add hardware. There, it can manually detect the hardware.Thanks and God bless^_^
godlover
SOURCE: My Acer Aspire 5570Z laptop's power button issue
Underneath the power button that you see is a small board with a tiny tactile button. These tactile buttons because they get used alot tend to go bad. They will get worn out and then eventually won't work.
Best thing to do is to go to this page courtesy of Acer:
https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
There is a phone number there and they should be able to tell you if your laptop is under warranty. If its not, ask them the name of the board underneath the power button and its part number and you can search for it yourself on the internet to get the best price
SOURCE: ''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
SOURCE: Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Testimonial: "Exactlt what I had been thinking!"
