HP LaserJet 3030 All-In-One Printer Logo
Question about HP LaserJet 3030 All-In-One Printer
My hp laserjet 3030 keeps reading 79 error power on power off
I FOLLOW THE GENERAL SOLUTIONS IN THE NET, BUT THE PRINTER KEEP READING 79 ERROR
Posted by onitshabumaz on
Andy Brasfield
  • 25 Answers
79 errors are often fatal. Your only hope is to get it back to READY, then update the firmware before it reverts back to 79 ERROR. The other option is to replace the formatter, but it would be about the same cost to replace the whole machine.
Posted on Apr 07, 2009
Michael Smith
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Methods to Fix Error Code 79:
Method 1: Unplug the power cable
You need to make sure that HP service Error 79 is installed properly. Sometimes disconnecting the power source may solve this error. You have to unplug the power cable to apply this method. Follow the steps mentioned below to proceed:
Ā· Disconnect the HP LaserJet Printer 3050 Power cable
Ā· Wait for at least 2 to 3 minutes
Ā· Connect your power cable again
Ā· Check if the error is resolved. In case if the error still persists, you can try using the next method.
Method 2: Perform other tasks
Step 1: Network replacement
Replace your network cable and the cycle power
Step 2: Removal of Network
Try removing the network and the cycle power
Step 3: Remove the DIMMs of the Printer
Try removing DIMMs for once and the cycle power
Step 4: Test the motherboard of the printer
To test the motherboard, you will have to print by using parallel interface through parallel cable.
Step 5: Cold reset
When the network is removed, perform a Cold Reset in the printer
When the network cable is removed and the problem still persists, try replacing the Network or EIO Card
Step 7: Replace the DIMMs Firmware of the printer
Next, you will have to perform the action of replacing the DIMMs Firmware
Step 8: Try replacing Formatter Board
If the error still exists, users can replace the Formatter Board of the Printer
Method 3: To fix Error 79 Error, Update the Drivers of HP LaserJet Printer
Often the old drivers in HP LaserJet Printers may cause the difficulties. Therefore it is important to update the printer drivers on time.
The above-mentioned methods will surely help in troubleshooting this error. If you still find this error in your HP LaserJet Printer, then you will be required professional help.
Get in touch with us via HP service Error 79 Technical Support Number for the right assistance. Website: HP 79 service Error
Posted on May 03, 2021
2answers
HP LaserJet Pro 100 M175nw Wireless Color All-in-One. How can I do a factory reset? I can't find a solution on the web.
Question edited for clarity. Full make model.
A factory reset won't fix firmware crashes or errors on updates. The firmware is what the machine does before the software is loaded and how it is loaded. A Reset, only reloads the operating software. Error 79 is an easy fix though. You will need to take it to an HP Service Centre if the firmware update is the issue.
It sounds like the printer is holding a print job in memory since it is showing " Printing Document" now on the display. Print Jobs are Stuck in the Print Queue. Disconnect any cables from the printer, except the power cable.
79 Error Message - HP LaserJet Pro 100 color MFP M175nw
https://h30434.www3.hp.com > td-p
HP LaserJet Pro - 79 Errors ' HPĀ® Customer Support
https://support.hp.com > ca-en > document
Solution: 79 Service error Turn off then on ... If the message persists, disconnect any network or USB cables and power cycle. If the printer returns to Ready, ...
HP LASERJET M1522 NF 79 error what is it?
Hello i hope u 'll be fine.... thanks for using fixya.
NF 79 is actually an
internal firmware error. It means unit has encountered an firmware error internally.
To solve it try this
If printer is plugged in to a surge protected extension lead then remove it and plug it directly in to the wall socket.After it retry.
If this fails again, then replacement of formatter of the printer is best option.
Best of luck
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
1helpful
My hp laserjet 3030 error codes 79
It's an internal firmware error. Power it off wait 30 seconds and power it on. If error code is still there, you will have to upgrade the firmware. If problem persists..replace the formatter.
Hp 3030 printer give up a error 79 pls tell me what i do in this printer
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
2helpful
2answers
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
1helpful
2answers
After getting error 79 won't print
A solution:
  • Unplug
  • Let go of buttons
  • Hope it works for you
6helpful
2answers
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Hp laserjet 3030 problem
Remove and replace the side covers again. One of them (I think right) has a tab that pushes an interconnect lever that if not reinstalled correctly or carefully will cause this error.
Here's the HP Service manual to walk you through it again.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%203015%203020%203030%20all%20in%201%20sm%20MFP.pdf
Hope this helps you.
5helpful
2answers
Error 79
Error 79 -product has experienced an internal firmware error Solution-disconnect power cord wait at least 30second ,then reconnect the power cord wait for product to intialize.If error persisit upgrade firmware
Clive
Clive
Ben Johnson
