Question about Seloc Mercury Outboard Repair Manual, 1965 - 1989, 40 - 115 HP, 3 - 4 Cylinder, 2 Stroke, 1406
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Fabrice Wolters
    Sergeant:
  • 331 Answers
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Posted on Mar 08, 2015
How much does a 1996 Mercury outboard motor 115 hp weigh
FourStroke 150 hp - Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/75-150-hp/Mercury FourStroke outboard motors are incredibly powerful and efficient, and they feature a wide range of applications. Crafted for less weight and high displacement, they generate abundant torque and immediate power. ... 150 115 90 75. HP / kW‎: ‎150 / 110
Engine type‎: ‎8-valve single overhead cam ...
Dry weight *Lightest model available‎: ‎455 lbs / .
Jun 13, 2018 | Mercury Boating
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Please only marine mechanics reply I have posted a question about my 90 hp force outboard the warning sound starts sounding while running full throttle after about 15 minutes of running full throttle I can...
Is this motor used in salt water?
That warning buzzer on your motor is really only tied to the temperature. In order to triage sensor or overheat condition, I'd recommend an infrared thermometer to get a reading on the engine as the buzzer is sounding. There is a product that is like a glue stick which can be pressed against the engine which melts at a very specific temperature... not sure if it's around anymore as the remote thermometers are pretty inexpensive now. Is there good water flow out of the ports below the cowling on the back?
May 01, 2017 | Mercury Force Starter, , Sport Jet,...
Make sure the fuel tank is venting properly and the pump bulb is new and working properly! Other than than you have an ignition advance module that is not working as it should.
Oct 29, 2017 | Boating
Seloc Mercury Outboard Repair Manual, 1965 - 1989, 40 - 115 HP, 3 - 4 Cylinder, 2 Stroke, 1406 Logo
1,872 people viewed this question
Top Seloc Boating Experts
Marvin
Marvin
Bill Boyd
Dariusz Zalewski
Dariusz Zalewski
Are you a Seloc Boating Expert? Answer questions, earn points and help others
