Question about Lexmark C510n Laser Printer
Lexmark c510 error code 900
Straight after self test the error appears
Posted by jan3477 on
  • Anonymous Apr 17, 2009
    dsa
Don Farrell
    Genius:
  • 1,018 Answers
Please fllow the appended link to Lexmark's web page for theses errors.
Don
http://support.lexmark.com/perl/support/support.cgi
Posted on May 21, 2009
1helpful
My Lexmark C510 Laser Printer was giving me- 83 Photodev Cart Warning so I replaced Photodeloper but printer is not recognizing that I replaced it
To specify which supply has been replaced:
Make sure the printer is on and the Ready message is displayed.
  1. Press and release Menu until you see Supplies Menu, and then press Select.
  2. Press and release Menu until you see Replace Supplies, and then press Select.
  3. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  4. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  5. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  6. Press and release Return until the printer returns to the Ready state.
6answers
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
2answers
Lexmark c510 printer paper feeds out of tray for about 3 inches and and an error code "paper jam 201" appears. After the sheet is removed, the same problem continues. Help!
Here's a link to the Lexmark website to guide you on what to do when having that error on the printer. http://bit.ly/9dXHBa. Read the article and follow the instructions carefully. Hope this helps but if after following everything in the article and still having the same problem, your printer may need service. If that's the case, contact Lexmark at 1-800-LEXMARK(1-800-539-6275).
1helpful
Lexmark C510 not printing - message 900 service RIP software
Hi, This error could be due to several things, the most common one is that whatever is being sent from the computer is not being recognized by the printer causing the 900 Rip Soft Error. You can try to reset the printer and try sending the print job again. If the error persisted. Then the problem could be a hardware problem with the System Board.
1helpful
2answers
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
I have a error message on my Lexmark C510 printer that reads: Invalid Engine Code. The printer will not print. Any suggestions
Recycle the power a few times, if that doesn't work first reflash the engine firmware (you would need to contact Lexmark for that) failing that replace the engine board.
Lexmark x422
900 RIP errors are errors in the Engine Code. There is an EC1 file available at: http://support.lexmark.com/perl/support/support.cgi.
Download and install the file by following the link on the above page, first error discription.
Don
1helpful
Lexmark C510 - Printer will not print
Message:
Invalid Engine Code
What this message means:
The printer engine code has not been programmed or is not valid.
What you can do: [Not much]
Call for service.
See also: Calling for service
1helpful
3answers
Lexmark C510 Code error: 995 Service Engine Error
Lexmark C510n Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
