these symptoms means that a new battery is required. the phone's battery is exhausted after a long time of use, replace the battery and the problem is solved.
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
I suggest you remove the battery and test it with another similar phone to see if it will charge, if it does, it means the battery is ok but if it did not, it means the battery is bad and need to be change.
But if the battery is good, it means the charging port is bad, all you need to do is to change your charging port because that is the next action place to check.
Looking at this two areas should profile a solution to your problem.
1. The charger may be damaged
To check if the charger is damaged, use another functioning charger.
The charger cable has a tiny wire that easily breaks when used without proper care.
If the phone still does not charge with a functioning charger, try next step.
2. The battery may be damaged
Change the battery and try charging again.
If the phone still does not charge with a functioning battery, try next step.
3. The battery terminals may not connect properly with the battery connectors
Check the battery connector to see if the battery and the connector connects well.
The phone will indicate charging only when there?s enough power supply from the battery. click here
Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step.
4. The charging pin may be damaged or does not connect well with the board's interface
Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board.
Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers.
Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution.
Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection.
The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged
If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
*#3371*
