Panasonic Lumix DMC-FX8 Digital Camera Logo
Question about Panasonic Lumix DMC-FX8 Digital Camera
Black screen sensor not working
2answers
My screen is black
Does the screen work in menu mode or playback? If so then the shutter may be stuck in the closed position. Compact and bridge cameras work on "live view". The picture is live feed from the lens. Obstruction to the sensor (usually the shutter) will prevent live view.
My screen went black in the middle of a call and has not turned on since then. I have plug it in and plug it into a computer nothing.
It appears your light sensor may be dirty or faulty, also, make sure you take off any case you have on your phone. The iPhone is designed so that when you put the phone to your ear, the screen goes black to conserve power and to prevent you from hitting buttons on the screen accidentally. If cleaning your screen doesn't work, you might want to have the unit checked out at your local apple store: www.apple.com/retail/locator/
A few other solutions may be to attempt to trigger the sensor again by moving a finger over the light sensor, or by shaking the phone, sometimes this has solved the problem.
1helpful
When I turn on the camera the screen is black. The digital screen works for menu options but is completely black when trying to take a picture
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to Olympus service centre. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
2answers
The rec nav radio screen has grey black and white lines and nothing else
If you ever found an answer to your problem I would really appreciate the help. Mine just started doing the same thing today. The screen has lines on it but the sound works fine. 2005 Jeep Grand Cherokee Limited. Thanks
My screen keeps turning black. i called last week because it happened to me before and they told me to take the battery out and press the power button for 15 seconds and put the baterry back, so i did and...
It is possible that you have a sensor problem which is a hardware issue. Cleaning near the top of your phone sometimes restores the sensor function. If you have a screen saver it will have a cutout for the sensor. If you look carefully you can find it.
But, have you gone into Settings/Display and looked how long it is set for before it goes to Sleep?
For my personal use I set mine to 2 minutes before Sleep/Black Screen.
23helpful
5answers
Black screen when camera is turned on
hi.. I also had this problem with canon ixus 75. i took it to the service center and they just knocked its lens(lightly) when it was on ON mode, then suddenly the screen started working.
But he said that u should use it on regular basis for few days and if the problem occurs again. then we will have to change the sensor, I think he said sensor or something like that.
Aug 11, 2008 • Cameras
Thick Black Line on Screen
This is caused by dead pixel sensors. There are hundreds of pixel sensors at the edges of the screen, when they go out it will cause a line varying in size depending on the amount of sensors that go out, and the line can vary in color, red, blue, green, white, and black. Unfortunately, the only fix for this is to replace the screen.
1helpful
Pictures are black
If you can display pictures in playback mode but screen is black in capture mode then the CCD sensor has stopped working and needs replacing.
3helpful
Panasonic digital camera has black screen
CCD sensor faulty especially if you can play back pictures that were captured properly, but have a blank screen in capture mode. Replace sensor and camera will work fine.
Screen appears black
your camera has a broken image sensor i.e. CCD. contact your nearest camera repairer to change the same, the only solution.
Top Panasonic Cameras Experts
Narseman
rhodesworks
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
