Question about HP LaserJet 4 plus Printer
13 Paper Jam - but there is no paper inside!
My old printer has always worked well. All of a sudden it says there is "13 Paper Jam" when no paper has become jammed. The last page printed out fine and had no tears or folds. How can I reset or bypass this problem as I have taken apart the printer and can see no paper jammed! It won't let me reset when pressing the "Reset button". Always returns to 13 paper jam.
Thanks
Corinne
Posted by meunier on
S. Marusic
    Scholar:
  • 62 Answers
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Posted on Apr 07, 2009
It says paper jam remove toner but there is no paper jam at all
Try power cycling the printer. Otherwise there is a paper jam or a sensor is dirty. Every time I hear someone say there is no paper jam I almost always find one. Use a flashlight they can be very very small.
Dec 18, 2012 | Office Equipment & Supplies
HP p2015dn I can't find error 13.000 in the manual
13.XX error msg almost always refers to a paper jam. Paper jam can be an actual paper jam, can be a sensor that is broke or stuck in the wrong position, Could also be a false paper jam. Printer tries to feed paper, paper never feeds, causing the paper path sensor to say "hey, that sheet of paper never reached me, so it must have jammed somewhere. Check the paper path for a paper or piece of paper.
Jul 21, 2011 | Office Equipment & Supplies
Paper jam
check if there is any piece of paper is jamed inside your printer i think that is why your printer always says paper jam
Jul 08, 2010 | HP DeskJet F380 All-In-One Printer
Paper Jam
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 30, 2009 | Canon PIXMA MX300 All-in-One Printer
My printer always said ''open back cover and then remove the paper jam'' what's that means? also can't print anything.
open the back cover to remove any paper jam on your printer, follow on it. Maybe there's a paper inside hanging in the ruler, take a look.
Jul 22, 2009 | Office Equipment & Supplies
PAPER JAME CODE 13
Try looking for the jam from the rear of the printer. Also, using one of those compressed air cans, blow all the paper dust our of your printer, because the sensors usually are photo-electronic sensors, and paper dust wil register a paper jam, even when no paper is in the printer.
Jun 19, 2009 | HP LaserJet III Printer
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
HP LaserJet 4 plus Printer Logo
1,518 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
