Bialetti Brikka Espresso Machine Logo
Question about Bialetti Brikka Espresso Machine
Bialetti classic valve popped out - Bialetti Brikka Espresso Machine
Bialetti Coffee maker repair
Sure it can. http://www.bialetti.com/coffee/stovetop/moka-express/spare-parts-c-1_7_22_32.html or http://www.amazon.com/s/?ie=UTF8&keywords=bialetti+spare+parts&tag=googhydr-20&index=aps&hvadid=32661633397&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3217975301600862448&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_53u2x7ta30_b
I have a Bialetti mokona and every time I turn it on water leaks from the hub, it seems to go anywhere but through the handle.
Make sure the tank is properly in place. This happened to me.
Give it a wiggle and see if it pops down properly...
1helpful
2answers
The pressure valve on my Mukka Express doesn't pop up. Instead after 10 minutes the valve is forced off. I rinse it really well and have even put it in boiling water. How do I get it to pop up?
I have the same problem. I cleaned all the parts, changed the pressure valve, cleaned the gasket, filters, everything. I hear the steam escaping from the overflow valve and if at that point I manually pull the valve up, then it does (barely) pop and steam the milk, but not as well as it used to.
1helpful
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in with...
I had the same problem and saw this solution in another bialetti mukka problem report, which made sense: "the safety valve on the lower boiler chamber is there to release pressue in case too much prssure builds up in the pot when brewing. If youy have an 11 mm wrench you can take it out and clean it by pulling on the outsidepart, there is a little knob that may be grabbed by a tweezer, gently pull it out, it is spring tensioned, and run water in the opposite end, Chances are some coffee grounds particles got in it and it is not seating good. after cleaning put a few drops of olive oil in it , the inside part. Should seal better and still funtion as a safety valve. Or you can leave it in place in the pot and just pull on the outside , flush with water and then put a few drops of olive oil in it. While you are at it, put olive oul on the threads, olive oil film and the the rubber seal and add a little to the rubber button on the top valve."
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine,...
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
I need a new handle for my GB Musa 6 Cup coffee maker. I am from Quebec City, Canada. Where could I get one of these?
It's a Bialetti Musa. The GB stands for Guido Bergna, the designer.
I haven't seen handles on any parts site, just gaskets and strainers.
You might contact Bialetti Canada, or Bialetti USA and get a handle.
CANADA
Toll Free:
800.667.4978
Mail:
Bialetti c/o Stonehaven Group
1880 Ellice Avenue
Winnipeg, Manitoba R3H0B9
email:
[email protected]
USA
Toll Free:
800.421.6290
Mail:
9409 Buffalo Avenue
Rancho Cucamonga, CA 91730
email:
[email protected]
[email protected]
Apr 05, 2011 • Vacuums
3helpful
I have just blown the valve on my bialetti cappuccino maker, can I reuse it?
The valve no, it is dangerous. Steam under pressure is a bomb. If you can detach ?unscrew? the old valve and find a new one, it will be fine.
2helpful
My Bialetti mukka expresso maker won t push coffee into the top chamber the pressure valve pops up but the coffee doesn't come out.
hey, it might be congested - this happens sometimes when coffee grounds get stuck in any part after a while - take the whole thing apart, including the gasket and filter and scrub everything out, then do a water run (no coffee) just to clear the thing up.
The problem might also be with coffee ground stuck in the pressure valve nozzle. Run water through it to see if it spurts out to check if there's any obstruction.
To get rid of the stuck ground in the nozzle, i once used a piece of dental floss twisted to reach within the nozzle.
hope this works for you!
Top Bialetti Coffee Makers & Espresso Machines Experts
Marvin
Marvin
David Shaub
Kolbrun...
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
