Question about Omega 1000 Juice Extractor
Juicer vibrates Vibrates to much
    New Friend:
THE SOLUTION TO VIBRATING. If it spins up ok and starts vibrating suddenly as you are feeling it, here's the solution: feed it very, very, slowly. that's it. i couldnt figure mine out, then realized that if i fed it slowly, it was just fine.
Posted on Nov 01, 2013
JUICER DOES NOT WORK CUTTER BLADE DOES NOT STAY ON TIED / CLUTCH LOOSENS/ JUICER VIBRATES WHOLE JUICER ALMOST JUMPED OFF COUNTER/ HOW CAN I KEEP CUTTER BLADE STAY TIED ON WHWN JUICING?
Contact the maker direct, we are FIXYA dot com and I am guessing you think we are the maker as you don't mention a make of model. Also check the instructions as my guess is that you may have it assembled incorrectly.
Jul 24, 2018 | Juicers
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
Excessive vibration and rattling when I have less than a cup of juice extracted.
I've had an Acme for 21 years and I don't care
what anyone tells you-they vibrate. After years
of trial and error I found mine vibrates less with
a worn blade that I sharpen with a drill. With
a new shredder blade you actually have to file
down the cutting burrs about one third and
adjust the blade to chute gap by unlocking
the adjusting screw on the center of the bottom,
turn it clockwise until blade contacts chute, and
back it off a half turn. Apparently with a slightly
duller blade, smaller gap, the produce goes through
more slowly and evenly. Also severe vibration will
cause the blade to jump up and chip the chute.
Dec 24, 2010 | Acme 5001 Supreme Juicerator Juice...
My Acme 5001 Juicerator vibrates around on the countertop. The rubber pads seem to be falling apart. Can I replace them? Where do I get them? Thanks David II
Dave, contact Waring at 1-800-492-7464 and order
a new foot ring. Here's a tip. When the juicer is
not in use find a bowl cover or something to fit
in side the circumference of the foot ring for the
juicer to rest on. That way the foot ring won't
stick to the counter and rubber won't compress
over time.
Nov 09, 2010 | Acme 5001 Supreme Juicerator Juice...
Motor has stopped:( I think its broken
Look for a red reset button on bottom of juicer. It usually trips
when the juicer vibrates too much.
Oct 16, 2010 | Acme 6001 Juice Extractor
My Omega Juicer 1000 shakes violently and the entire machine rotates unless I firmly hold it or turn it off. It's been in the closet for good seven years before I took it out and started using it. It's...
Make sure the bottom of the feed chute is not damaged. If it,s chipped or scored, try filing
it down level as best you can. Then with the juicer fully assembled, unlock the set screw
on the center of the bottom and turn it clockwise until the chute contacts the blade, then
back it off a half turn and lock it down. By the way a dull worn blade will produce less
vibration. I'm assuming the lid is plastic.
Sep 28, 2010 | Omega 1000 Juice Extractor
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
The 6001 vabrated so much the top came off and the flang bent.
WARING AT 800 492 7464 HANDLES ACME
JUICERS. VIBRATION MAY NOT INDICATE
REPAIR. THIS JUICER DOES NOT EJECT
PULP SO IS PRONE TO VIBRATION JUST
LIKE AN INCORRECTLY LOADED WASHING
MACHINE. HOWEVER, SEVERE VIBRATION
WILL CAUSE THE BLADE TO CHEW UP THE
CHUTE. YOU WILL NEED A NEW COVER.
TALK TO WARING. ANOTHER PROBLEM
IS NEW COVER PROVIDED WILL NOT FIT
SOME OLDER JUICERS WITHOUT FILING
DOWN THE EDGE OF THE COVER. TAKES
TIME BUT CAN BE DONE.
Jun 24, 2009 | Acme 5001 Supreme Juicerator Juice...
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
Jul 01, 2008 | Acme 5001 Supreme Juicerator Juice...
Omega 1000 Juice Extractor Logo
263 people viewed this question
Top Omega Juicers Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Ernest
Ernest
Are you an Omega Juicer Expert? Answer questions, earn points and help others
