Blodgett (ZEPHAIREG-DOUB) Double Oven Logo
Anonymous Posted on Aug 16, 2013
Wont heat temperature - Blodgett (ZEPHAIREG-DOUB) Double Oven
2answers
What can should i do? what can be the issue?
Unfortunately the Self clean function will often break ovens. The heat is just too severe and breaks elements, control boards and the door locks and wiring. You need a service call. If you are VERY lucky, disconnecting the power at the breaker for an hour MAY release the lock and error message.
Self-Clean Ovens
The oven is cleaned by heat, at temperatures above normal cooking temperatures. During the cleaning cycle the oven is heated to about 880 degrees Fahrenheit (471° C.). At this temperature, food soils inside the oven decompose, leaving behind a small amount of ash.
My advice is never use the self clean function.
Nov 09, 2021 • Ovens
My Frigidaire dual fuel oven wont get hot. Both heat elements and temperature sensor have been replaced and it still only gets warm. No error codes are displayed.
Thank you for your post, Chrissie!
I understand that your Frigidaire duel fuel oven is not heating properly. I see that you have replaced your temperature sensor and heating elements and your oven is still not working. This could be a possible issue with your control panel or wiring harness. Since it could be anyone of these underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
I have a Lincoln Impinger Model No. 1301/1346 electric counter top oven that wont heat up at all, what could be the problem
After powering on set the temperature to cooking temperature. since its electric it is less problematic. if there is no alarm then check the probe.
7helpful
3answers
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
My oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Please rate my solution.
Thanks.
1helpful
OVEN TURNS ON BUT WONT HEAT UP.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Top Blodgett Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
