SOURCE: replaced control on u-line 75WC wine cooler now runs constantly
If the sensor of the thermostat is not on the evaporator plate then yes the thermostat will never be satisfied. Because it is not reading air temp only the evaporator plates temp. should be clamped onto the bottom of plate.
Testimonial: "Going to check and thanks for the response. I am 99% sure this is the probelm!"
SOURCE: wine fridge thermostat
No pictures, the new one goes in the same as the old one comes out. You have 2 screws on the bottom of the evaporator that holds the sensor in place. Then the sensor runs thru the bottom toward the back.As you remove the old one jus put the new one in the same way.
