Question about Insignia LCDTV26 26 in. Television
VCR picture with INSIGNIA 26'' lcd tv
Hello
When i had my old tv. The VCR worked well: I can see picture moving when i push ''PLAY'' bottom and '' FORWARD'' bottom.
With my new tv ( Insignia 26'') when i do same thing about the vcr, it goes forward ( or rewind ) but i don't have any picture so i don't know when stop the forward or the rewind. What' s solution about that?
Thank you
Posted by karimbad on
  • karimbad Apr 07, 2009
    I select the correct tv input. My vcr works well but when i push '' play'' and '' forward or rewind'' it goes forward but i don't have picture so i don't know when stop the forward. Thanks
Anonymous
  • 3 Answers
I would check if you have selected the correct tv input on you remote. the shadow movement you see may be bleeding over from another input. on your TV remote you will see "input", keep clicking it, delaying a little each time, until you get to the correct input you are connected to.
Posted on Apr 07, 2009
VHS pictures shake
Did you try adjusting the tracking control on machine?
Sep 21, 2017 | Insignia LCDTV26 26 in. Television
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
Nov 25, 2008 | Televison & Video
INSIGNIA 26" FLAT SCREEN MODEL #246ALC27FB26006527
These LCDs have a feature to turn OFF after some time if they do not sense any signal getting into the TV, that is why when you use it as a PC monitor and leave ON; it will turn OFF by itself.
The short term solution to make the LCD power up properly when using it as a PC monitor would be to unplug it when it turns OFF by itself and plug it back in.
Let me know if you need further assistance.
Oct 24, 2008 | Insignia LCDTV26 26 in. Television
Stand Alone VCRs do not play pictures on my Insignia 24" TV
Did you try using teh SV cables supplied or the RF cable?
Easier to use the AV Cables. 100% should work. Connect Video OUT of VCR ro VIDEO IN of TV and AUDIO OUT (L) and (R) of VCR to AUDIO IN (L) & (R) of TV. Select AV or VIDEO on TV using TVs remote. Play a Cassette. should work!!
Apr 04, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
My Insignia 26" lcd tv has a built in dvd player that doesn't work.
I would suggest to call the place where you bought it and ask them for an authorized repair center. You TV still under manufacturers warranty.
I could fix it for you. I live in Brampton.
Good Luck.
Mar 18, 2008 | Insignia LCDTV26 26 in. Television
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
50 inch insignia plasma
THIS BRAND OF TV IS NOT REALLY RELIABLE AS IT IS ECONOMICAL YOU SEEM TO HAVE A POWER SUPPLY PROBLEM MOST LIKELY A POWER CONTROL BOARD ISSUE .
IT WILL BE MORE ECONOMICAL TO PURCHASE A BETTER BRAND NAME TV AS THE INSIGNIA BRAND PRODUCT IS ECONOMICAL PARTS ARENT AVAILABLE.
Feb 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia 20 lcd
Bell expressvu remote code for insignia 26” HD LCD TV NS-LCD26F/NS as sold by Best Buy in Canada is 220.
Dec 30, 2007 | Televison & Video
Insignia LCDTV26 26 in. Television Logo
99 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
