SOURCE: blinking picture
TV Repairman came out today to look at my Sony KV-36XBR250 today with the exact same problem - he was able to adjust the settings through the service menu, but said it was a temporary fix only.
The picture tube is going and the Sony circuitry has a "video mute" that it uses when it senses the tube is not warmed up enough. The degraded state of the tube causes the blinking on and off as the signal from the tube wavers.
He ballpark estimated the tube replacement cost well above the price for replacing the set with a 37" LCD, so it's going to the dump...
SOURCE: Sony Wega Trinitron KV-27FS100 blinking 5 times
Hello pityk, here you can find the manual of your product if you dont have it,
http://www.fixya.com/support/p228950-sony_fd_trinitron_wega_kv_27fs100_27_tv/manual-16228
This is the troubleshoot section
http://www.fixya.com/support/p228950-sony_fd_trinitron_wega_kv_27fs100_27_tv/manual-16228/page-50
SOURCE: blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
SOURCE: Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
