SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
Sorry to ask so many ????? Let me know how it goes!! T.
