Question about Jenn-Air ® Ventilation System for Custom Hood Installation, JXT7036A
Fan olny run on hight speed
Posted by a0kapa01 on
Tracy Farrell
    President:
  • 331 Answers
The fan speed selector switch has failed and needs a replacement. Here's the parts breakdown for it. It's number 26 in the diagram.
SG
Posted on Apr 07, 2009
Blower motor blows high whenever ignition switch is on
Sounds like your fan switch could be shorted out
Apr 14, 2015 | 2000 Chrysler LHS
Blower motor works only on hight speed
Most heater fans have a resister built into the wiring and connection block on the actual casing. High fan speed=full voltage, Mid speed=small resister, Slow fan speed=large resister. Change the resister block. Pete
Sep 30, 2013 | 1998 Chevrolet Malibu
Dtc code p1490 fan olny comes on when air conditioner is on
P1490 Low Speed Fan CTRL Relay Circuit. You need to check and make sure the cooling fan is coming on when the engine reaches operating temperature and when you turn the A/C on. If not, replace the Low Speed Fan relay.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 23, 2011 | Mitsubishi Eclipse Cars & Trucks
The ac is on full at all times, even when you adjust the fan hight. someone sayed i need a a/c auto amplifier. but i can't find that part
Good Evening, If I am translating this properly your fan only works on the high setting? And the other settings do not change the speed? If this is correct respond back and I will help as much as possible.
Nov 06, 2010 | 2001 Nissan Pathfinder
Fans run at high speed , blue light comes on, i get no video.
Hello
OK, firstly., if the fan runs at hight speeds, it is an indication of the CPU overheating.
If you do not get any beep codes, Your motherboard might also be damaged.
Let me know if you are getting any beep codes.
Also, if the CPU is blown, you will not get any video, because the CPU is not processing anything.
please let me know if you are receiving any beep codes, so we can start troubleshooting.
Kind regards
Andrea
Sep 10, 2010 | Dell (E210882) Motherboard
My car fan went up to hight speed on its own. Can't turn it off anymore. Even when I turn off the car the fan keeps running. took out the maxi fuse to stop it. any suggestions? thank you
Ok 2 things. 1. The temp switch is stuck. 2.The relay for the fan is stuck. If it's the temp switch in the block it will need to be replaced. The relay can be replaced for about 15.00. Labor will be more.
Dec 19, 2009 | 2003 Saab 9-3
Goldstar dh305y6.will olny run sometimes then shuts off it does collect water but it will olny run a few minutes. other times will not run at all it a dehumideifier
Sound like you need a good cleaning of the evap and condensor. The make sure the fan is running. If nothing runs then check your thermostat.
Aug 31, 2009 | LG DH30 GoldStar Dehumidifier
Jenn-Air ® Ventilation System for Custom Hood Installation, JXT7036A Logo
190 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
