Alpine MRD-M301 Car Audio Amplifier Logo
Anonymous Posted on Apr 07, 2009
Need help on this model amp is there a code that has to be put in for it to power up....
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jun 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
4322
Points
16
No, needs repair..Contact ALPINE ELECTRONICS OF AMERICA, INC. 19145 Gramercy Place, Torrance, California 90501, U.S.A. Phone 1-800-ALPINE-1 (1-800-257-4631)
What does a code 35 with a double beep mean?
Hello,email the Manufacturers website with your Model No + Trip Code & ask for advice on getting it fixed.I hope this helped,who better to ask than the Manufacturers.Via Fixya.com.Colin
Catalyic system failure
We need a more complete story & some detail here, to
offer a suggestion
How about a year,make,model,engine & some codes
PO 420 & 430 codes are worn out exhaust converter,
below efficiency, as you said failed
You can put any code or question in to google,etc & get
all the education you need & print out code charts & fix info
3helpful
How removed toner indication still toshiba copier e-studio-181?
toshiba e-studio 181 toner indication patmanent still.
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
I need to put steering wheel fluid for my 05 chevy equinox don't know where to put it in. Can someone please help me?...
2005-2009 models used electric power steering assist exclusively. There is mo power steering pump, reservoir, or fluid on these models. Instead they use an electric motor mounted to the steering column to provide steering assist 2010 models still use the electric power steering on the four cylinder models but also use a conventional hydraulic power steering on the v-6 models. If you have no power steering assist check the 60 amp main fuse for the power steering in the under hood fuse block if that is o.k. You will need a scan tool to find out what is wrong with the system. It is not uncommon for the electric motors to fail or for the fuse to blow while jump starting the vehicle.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
My new laptop screen is black, I tried taking battery out and putting back in , it didn't help. Please help!
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Need a code for an emerson tv can't view dvds
I need more info about the remote! like Brand and model !
even without code! You should be able to put the remote into a search mode.
Here is some common procedure;
Put the Remote in search mode, while directing it to the turned on TV, push the power button repeatedly when the TV shuts down you should push the OK button immediately!
If you know the model and brand of the remote I might be able to help you more precisely
GL
2helpful
Need amp for 2 15 l7 4 0hm
Hello jasonjohnson,
There would be more amp choices if those L7's had the 2ohm voice coils, allowing you to series the coils and then run the subs parallel to the amp for a 2ohm load. As it is, you'll probably have to run them as either 1ohm and have limited amp choices, or as 4ohm and settle for a little less power.
An absolutely excellent amp to use at 4ohm would be the Alpine MRP-M1000. At Crutchfield this one is on sale for $347. For more power, and an amp stable to 1ohm, I would recommend the Rockford-Fosgate Punch 1000-1bd, a "factory refurbished" model is available at Crutchfield for $349.99. It's $700 new.
Both of these amps have adequate power for 2 L7's, but the RF will definitely be the better power choice. Both are also well respected names in mobile audio and the prices are reasonable.
If you have deeper pockets and want to push the subs really hard, a Rockford-Fosgate Punch 1500-1bd will put a full 750 watts RMS to each sub.
Hope this helps.
2answers
Orion 2400 mono
My esp light is blinking yellowish and the amp isn't putting out. I have power to it, just not putting power to my subs. anyone know how to help?
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
