Question about JVC Video Cameras
JVC Camcorder- Recording Problems
My JVC GR-D70U Camcorder does not display Visual Image for RECORDING. Neither on LCD screen or Viewfinder. Shows recording in progress but nothing is being recorded.
Anonymous
    New Friend:
I have a jvc GR.D20EK and am having problems when recording, it plays back but i cannot record it will play recorded tapes can anyone help me. Thanx
Posted on Nov 05, 2009
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
GR-D71, no longer records images
CCD (imaging chip) went bad and require replacement. Not a very expensive repair, but has to be done by professional.
Nov 04, 2009 | JVC GR-D71 MiniDV Digital Camcorder
No visual through LCD or viewfinder
This is a Iris Problem .....THe Best in house solution is to Bang the camera Lightly with your palm .... other wise send it to a repairman .... coz you wont be able to open the camera to such an extent
Oct 14, 2008 | JVC GR-SXM260U Camcorder
Lens cap
You JVC GR-D70US camera has problem with CCD Imager and JVC will repair it free of cost.
Please click JVC Offer for details.
Regards,
Sep 10, 2008 | JVC GR-D720 Mini DV Digital Camcorder
JVC Picuture gets blurry
The ccd block is starting to fail. Thats the chip thats the eye of the camcorder at the back of the lense assy. Its mounted on a small circuit board. You can find the chip at parts.com. Its just a matter of dissassembling the camcorder and removing the chip from the board and soldering another onto it taking care not to over heat the chip. You do need good soldering skills.
Tim
Aug 24, 2008 | JVC GR-D22U Camcorder
Blank Screen when trying to record
Hi, the problem U have is the imager. reason: it is the way Sony made the imager... the gold lead wires would pop off the chip without warning. So go to JVC's site. they will fix it for free.
http://support.jvc.com/consumer/support/notification/index.jsp
Sidekar:-)
Feb 18, 2008 | Video Cameras
JVC GR-D50E Digital video camera - on LCD view image is not displaying
if you live in very cold region, the mist or moisture give you this problem, using a hair dryer will solve this problem.
Aug 20, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Problem with JVC GR-D70U
It's ... a. A broken connection. b. A failed chip or component. It is not something an owner usually can repair.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Richard C Cohen
Richard C Cohen
scramblepad
scramblepad
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
