Question about NorStar Nortel Aastra B0240402 Phone Ash M5208 24 x 2 LCD display MADN-capable(B0240402, M-5208, M 5208, 52...
I need to change the main voicemail greeting on our office phone. We have a Toshiba DKT-3020-SD phone. I have the security code to check messages left on the machine but that doesn't seem to be the same one I use to change the greeting. Is there a way to change the message without using a security code?
Posted by Nicole Steier on
5 Related Answers
Mike McWhinney
  • 537 Answers
SOURCE: Changing MAIN voicemail announcement
I am not a phone installer and we have another vendors' phone system here at our work.
It can be *extremely* difficult setting up these phone systems, even with a manual.
Here is one such link that might help:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Here is another forum that has lots of friendly folks that might be able to help
http://www.sundance-communications.com/forum/ultimatebb.php?/ubb/forum/f/8.html
You will get an answer much sooner on there than here probably.
Mike
Posted on Nov 09, 2007
Anonymous
SOURCE: Changing main greeting
You need to go into Feature 983 system admin. You need to get the password though.
Posted on Jan 03, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: How do you change passwords without knowing previous passwords in order to change voicemail greeting??
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
Posted on Apr 17, 2009
Anonymous
SOURCE: cannot change greeting when we are out of office. M7310 phone
Which greeting is it? If the AA greeting...try this.
But listen before you record, to make sure you are recording the correct thing.
http://dstech1.com/how-do-i-change-the-auto-attendant-greeting-on-my-nortel-voicemail/
Posted on Jul 06, 2009
consultel1
george peters
  • 860 Answers
SOURCE: understanding greetings and tables so that the
You can have the messages change using the greeting time tables, or you could record a seperate greeting and manualy change it from the standard greeting to the holiday greeting and back again at your leisure.
Posted on Dec 17, 2009
Create a voicemail for toshiba DKT 2010-sd
Hit your main voicemail interrupt greeting by pressing pound enter box 999 enter password usuallu 999 or 999997 but could be anything listen to prompts ti create mail
Feb 06, 2014 | Toshiba DKT-2010 Corded Phone
I have a Toshiba DKT3210-SD. The person who set the voicemail security code no longer works here. I need to reset the security code. Can you help me?
call your voice mail and log into mailbox 999.(dial the pilot number possibly 555 or 850 then hit the star key when you hear the greeting) the default security code for mb 999 is 999997.
Hit option 8 then listen to the prompts you can reset just the password or the entire mailbox. the new default password will be the mailbox numbe followed by 997. Ex Mialbox 200 new password will be 200997
Sep 14, 2011 | Toshiba DKT-2020 Corded Phone
Voicemail timestamp & "on hold" too long
Yes Music can be played from your system during transfer. Simple connect any radio or cd player to the RCA jack located on your KSU (main box) For setting the time in voicemail log into box 999 with sec code 999997 or just 997 and press 8 for admin features. More guides and ACTUAL manuals can be found here
http://guides.idacomusa.com/
May 18, 2009 | Toshiba DKT-2020 Corded Phone
Tell me the original security codes of zetel n82y phone
call the voice mail extension or get into voicemail in any way. when you hear a voice dial * then 999 then 999997 for security code or use 997. Press 8 for admin features and reset your box. Default codes are your extension number +997 or just 997. Here are your manuals
Apr 21, 2009 | Toshiba DKT2010SD Phone
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
Reset security code
I need to change the security code to voicemail. I have a toshiba dp5032-sd telephone. Can anyone help me ?
Nov 06, 2008 | Toshiba DKT-2020 Corded Phone
Toshbita DKT-2010 main phone message
Hi Matt,
If your voicemail is a Toshiba in-skin and your main greeting is under 991 mailbox then the last message you change before getting out of programming will be the active message so listen carefully to the prompts and make sure that your new message is the active one when leaving programming. Let me know if this helps. ....Mitelmike
Sep 17, 2008 | Toshiba DKT-2010 Corded Phone
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
NorStar Nortel Aastra B0240402 Phone Ash M5208 24 x 2 LCD display MADN-capable(B0240402, M-5208, M 5208, 52... Logo
55 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
