The flashing light indicates a fault. These flashes are called blinking codes. Count the number of blinks occur at one time switch ON. Counting of blinks to Philips is not done directly. It is a sort of coded. If you wish to get more details, check the site linked here. Counting procedure to Philips TVs is given in detail. Please keep some time with the instructions. It will be somewhat seem difficult to anybody who doesn't know anything electronics.
Pull up previous posts, either by type in the Brand name to
your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Select view option by the drop-down view box, at the top left or
the display window.
Testimonial: "Thanks for your post. However the flashing red standby light is constant, and it doesn't have a particular sequence just ongoing"
SOURCE: Philips TV 32PW9763/05
This is is due to a faulty resistor probably the B+(R950)..On the power supply control circuit..If you know how to use a multimeter you can easily find the faulty one...And replace it.However if you are not good at electronics i advice that you give it for service coz its not gonna cost you too much..Dont delay the repair as it can damage the more expensive components in the Tv.
Eagle.
SOURCE: philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
SOURCE: Red standby light flashing no picture or sound
the power supply is faulty, check the following
power trasistor
rectifier diodes
zener diodes
fusable resistors ( less than 20ohms)
and your set will work again
SOURCE: Beovision 3 (8803) standby ok - no picture - no sound
if you know how to use soldering iron,try to resolder your tv,especially the jungle,regulator and the horizontal section.if not working, check the output transistor a square black plastic w/ 3 legs at the back of the plyback.
584 065 040 041 582 221 115 071 351 402 034 219 451 371 035
Philips
14PT3685/05 21GR2550/058 21PT532A-05 21PT161B-05 21PT166A/03 MD12E 29PT828C/05 32PW9615/05 28PW6322/05 32BW6332/25 28WVRN 32PW952505 SL6-1 25ST1761 25PT727B/05 21GR2554/05B 28PW6606 21PT161A105 32PW9566/05R TW6328 28MD12E 28PT/4523/25 32PW9525C 28PT4521 24PW6006/05 32TW6517 32PW8515/05 32PF99445/12 42PF9945/12 21PT5505 23PF99445/12
Philips
20PV164/05 20PV230/07 24PW632405R 25PT4475/05 25PT4523/05 28PW6516/05 28PW5324/05 28PW6315 28PW6515 29PT9113-05 29PT828C/25 32PW6322/25 32PW631S 32PW6517 32VW6005 32PW962B 32PW6006/25 32PW6526/05
