humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Odd for both to be out. Check the water supply sometimes corrosion or scale will block the saddle piercing valve. Run it all the way into the pipe. Usually need to spin the little valve handle clockwise. Then back it all the way back to full open and reset humidifier power and furnace power. After that may want to crack open water supply connection right before the solenoid at each humidifier to make sure water is getting to them.
Your humidifier is a bypass type. The only voltage needed is 24vac to open the water valve. Air only flows through the humidifier when the furnace blower is running, and the wet pad will add very little humidity if the furnace is not running and heating the air before flowing through the wet pad in the humidifier.
It is best the water valve is only energized when the furnace is running. Some furnaces have a connector on their control boards labeled HUM for this purpose. Test it's voltage when the furnace is running because some will output 110vac instead of 24vac you need.
It's probably the saddle valve. The self-piercing needle rusts and clogs the water line. Replace the saddle valve with a non self piercing one. Also, check the voltage to the solenoid valve on the humidifier. You should be getting 24 ac volts. If not, replace the transformer. If voltage is present and still no water, then replace the solenoid valve (very expensive).
Hello, turn the water off at the saddle valve and turn off your Furnace. Then disconnect the wires from the solenoid and disconnect the supply water tubing from the solenoid and the outlet tubing, now unscrew the solenoid and replace it with new one and reconnect everything and open saddle valve and turn Furnace back on.
Hello, if there is water to the solenoid valve but not passing through it than the solenoid valve is malfunctioning and must be replaced. However, if there is no water at the solenoid valve then either the saddle valve or supply line is clogged with sediment. A easy way to chek the solenoid valve is apply power directy to the solenoid valve from the transformer, if it does not open then replace it.
The furnace should be equipped with a #50 relay to turn the Humidifier on and off when only when the furnace blower is on. You should have a test mode on your humidistat. Do you have water coming up to the solenoid valve? Make sure that the saddle valve is turned on to supply the water to the humidifier. Is your humidistat set high enough to turn the humidifier on? Is it plugged in?
Good luch
HVAC Teacher
Loosen the brass fitting where it connects to the soleniod valve. If water comes out your saddle valve is ok. Carefully retighten this fitting. With the humidifier turned on loosen the first fitting down stream from the valve see if water comes out. if it does turn the humidifier off and see if it stops, it should. That will tell you the the valve is ok then, just clean the filter and the oriface. if it does not turn on and off check the wiring. if ok replace the valve.
Good luck
Sounds as if you feel the problem is the saddle valve. Check to see if water is available at the humidifier. Close the saddle valve, disconnect the water line at the humidifier side, then slowly turn the saddle valve back on. If you never see water, then correct the saddle valve. You can get details here: http://www.naturalhandyman.com/iip/infxtra/infsad.html#1
If you are getting water, but dont think that the unit is operating try sending 24VAC directly to the hunidifier and see if it operates, bypass the humidistat etc.
