Nokia 9300 Smartphone Logo
Posted on Sep 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia 9300 i have a nokia 9300, when i use excell sheet in it, im facing a peculiar Problem, whenever i punch the number keys after Pressing shift key (the icons on number keys does not appear as they are printed on number keys)
Anonymous
Level 2:
Sergeant:
  • Expert 452 Answers
  • Posted on Oct 19, 2007
Anonymous
Expert
Level 2:
Sergeant:
Answers
452
Questions
0
Helped
321778
Points
710
U r shift key might have gone bad, u just go to nokia care and repaire it.
2helpful
4answers
Is it possible to get an unlock code for a blackberry curve 9300 IMEI 353039041609422?
It is very simple to unlock your Blackberry curve 9300 through Blackberry Mep Unlock Code. call your service provider . or buy your Blackberry curve 9300 Mep Code from third party. it is safe and trusted method to Unlock your Blackberry curve 9300.I hope this will help you :)Good Luck.
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
4helpful
How to format my nokia 9300i
CRTL + Shift + F
What is the format code for n 9300
Pull the battery out (or use a program like Roman Keller's Rebooter) and when the Nokia big and little hands are showing on the screen, press the CTRL, SHIFT and 'F' key at the same time. Your Nokia will be reset to its FACTORY state and ALL data will be lost, so be warned!
7helpful
Unable to delete call lists in my nokia 9300 What should i do? Is it a software problem?
What do you mean by Call list? If you mean the list which comes up when you press the GREEN KEY then it can not be delete from there! Open the communicator Press the TELEPHONE KEY then press RECENT CALLS Then select the tab you desire then click clear all.
If you want to clear the Call Log then open the communicator Press Ctrl + Shift + L & Call log will appear then Press Ctrl + D Enter the date before which you want to clear the Call log & press clear.
3helpful
Hi i have nokia 9300, but a few days ago cannot send the sms they said system not enough memory. Close some applications and try again. But still cannot i deleted all the inbox, sent and everything but...
ALL YOU HAV TO IS TO FORMAT YOUR NOKIA 9300 USING KEY CTRL+SHIFT+F, YOU MUST TYPE THIS KEY WHEN YOU PHONE STILL APPEARING THE WORD NOKIA ON BOOTING SCREEN DONT WAIT TO SEE THE HANDS IF SO U R LATE
Microsoft excel
This solution on average add 10 new worksheets in less than 5 sec.
Hold down shift key, then hit F11 as many time as many sheet you want to add
Other than SHIFT+F11, ALT+SHIFT+F1 also Insert a new worksheet, it's just to you which is more convenient.
Regards,
3helpful
Re-format
apparently this works
* Press and hold the following 3 keys until a Format Message is displayed:
CRTL + Shift + F
Unable to format nokia 9300
mate u just have to press ctrl, shift and f Not the chr key
1helpful
Keyboard characters
If u want to type special signs(which are in blue colour )  then u need to Press CHR+Sign it  will work if u want to type other symbol  ($%^) then press SHIFT+ that key which u want to type($%$%$.)
Gizmo1
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
