Cameras Logo
A
Anonymous Posted on Aug 15, 2013
Minolta maxxum 50mm f 1.7 - Minolta Cameras
5 Related Answers
Scargo
  • 51 Answers
  • Posted on Jan 20, 2008
SOURCE: QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Anonymous
  • 155 Answers
  • Posted on Feb 28, 2008
SOURCE: Sony A100 compatible lenses
Virtually all the old Minolta lenses are compatible with the new Sony SLRs.
For the two you mention, you will need to check whether the lenses are the AF or MF versions.
Both will fit, but AF is the auto-focus one, and MF is (obviously!) manual-focus.
If you want a definitive list with tech details on ALL the Minolta / Sony lenses, look here:
http://www.mhohner.de/sony-minolta/lenses.php
Matt
Anonymous
  • 480 Answers
  • Posted on May 23, 2008
SOURCE: Bracketing in Maxxum 5D
Hey arnelsartwor,
To set both exposure and flash bracketing you need to press the drive mode button, and then use the up/down arrows to select bracketing and then use the right/left arrows to highlight the drive mode option and then press the center button to select the desired drive mode. These instructions are on page 50 of your user manual. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
A
Anonymous
  • Posted on Aug 06, 2008
SOURCE: Minolta Maxxum 7xi Complete User Guide
Hi, look this:
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Anonymous
  • 11 Answers
  • Posted on Mar 15, 2009
SOURCE: "no lense attached" error message on my sony a200 with a sigma 70
It seems that you may have an older sigma lens which does not have the appropriate electrical connections. Sigma can modify this for you if you contact them, and I believe the cost is reasonable. Although some lenses look very similar, there are electrical differences between earlier and newer lenses, even though they may fit on to your camera mechanically,
What digital camera will interchange with minolta maxxum 7000 lens ?
The Maxxum lenses should work with just about any sony SLR
May 12, 2014 • Cameras
I need the manual for a Minolta Maxxum GT camera
The Maxxum GT is a Maxxum 3 relabeled for a single retailer. You may download a copy of the Maxxum 3 manual from here.
1helpful
What size lens fits a Minolta Maxxum 3xi??
It depends entirely upon what you're after and the type of photography you wish to undertake.
Any Minolta AF mount lens will fit. 28mm is a standard wide angle, 50mm is a standard lens with a field of view approximately the same as the human eye, 80mm is a slight telephoto and for distant subjects 200mm is a long telephoto. Some lenses combine a few into one, they're called zoom lenses and will typically be something like 35-70mm, or 70-200mm. The measurements relate to the focal length of the lens, but generally the larger the number the longer the lens sticks out at the front. Zoom lenses are bulkier and heavier than fixed focal length lenses, but they're also the most commonly used types these days.
Will a lens from a Maxxum 5 work on any digital slr's? And if so, which ones? I am looking to buy a new camera and would like to use my same lense.
The Maxxum lenses will work on Sony DSLRs.
The Sony models A100 to A700 will multiply the focal range by 1.5 because the sensor is smaller than a 35mm frame.
So a 50mm for example will be a 75mm f1.7.
On Sony A850 and A900 they will be the same as a 35mm film body.
I use Minolta lenses with my Sony bodies all the time and they are excellent.
Nov 23, 2009 • Cameras
I have a sony alpha 100 i want to buy a 1993 minolta maxxum 3xi with 35-70 and 70-300mm lenses. Those minonolta lenses are compatible with my alpha?
I took the following off of the Alpha website
"Sony Alpha lens mount
Identical to the Minolta A-type bayonet mount, enabling the use of a large back catalogue of existing Minolta and third party lenses"
I know that the lenses that fit my son's Maxxum will not fit my non-Maxxum Minolta bodies. VERIFY THAT THE LENS YOU WANT TO MATE TO YOUR SONY HAS THE MINOLTA A-TYPE MOUNT.
Bad Minolta Maxxum lens?
Oddly enough, the camera and lens are working just fine now - or at least they appear to be. I'll shoot some more when I have good lighting and 1-hour them tomorrow for the results.
Older equipment on newer equipment
Carry one of your lenses to a camera store and ask them to let you compair it with one for a Maxxum.
The Sony Alpha / Konica / Minolta mount is called a TYPE A bayonette mount. google the Maxxum and see if it accepts the TYPE A mount.
3answers
Minolta Maxxum HTsi plus
Minolta Maxxum lenses fit certain Sony digital cameras. Check this site as it depends on the specific model.
https://feltmagnet.com/photography/Digital-SLR-Cameras-and-Those-Film-Era-Lenses
Top Minolta Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
