Open the door around the front of the door seal you will see a lip under the lip you will see a metal band will a spring. get a screw driver and push in on the spring and pop it out. this will remove the front of the seal next is the same thing exept the band looks a little different locate the part that you can unscrew sometimes they have a socket head and sometimes it will have a phillips screw. when you are putting it back on it may be time consuming and you may start to cuss a little. you have to make sure the rubber goes on the right way so that the band seals and doesn';t fall off or you will have a leaking issue. also when taking the seal off you have to take the part that the water comes in off. just peal the rubber away from that plastic shoot. let me know if you have any more questions
SOURCE: Replacing the rubber gasket on Kenmore elite HE 3t
probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
SOURCE: Bosch front load needs new gasket
i think you mean the (door seal), and yes they can be replaced and at little cost and little effort, with out knowing what model your machine is i cant give you an accurate price quote but should be able to pick one up for for next to nothing if you look around. happy to give instructions on how to replace the old one if needed.
SOURCE: wide gray rubber gasket between door and drum is
the rubber will need to be replaced the cost is around $ 150 you can find washer repair service techs under washer repairs in your local phone book
best of luck
