Question about Acer Extensa 5420-5687 Notebook
I cant use discovery network tool, after I change my settings
I want to change my startup programs settings, I played around and change some settings that I not remember which ones, I restart my computer and then my computer was unable to see any network because the network discovery tool was turned off, I tryied to turn it on but I can not.
Posted by myri_mag on
  • myri_mag Apr 08, 2009
    Thanks, I will try and let you know.
marley mcelhinney
  • 490 Answers
This may help if yor laptop is vista, open the menu and in the search box type msconfig this will bring up a menu that alows you to choose starup programs and other options, hope that helps
Posted on Apr 07, 2009
My computer time is slow when l set my computer time after three or four days computer show last day and time is not corect
Follow these guidelines::
Free up wasted space with Disk Cleanup tool
Defragment your hard disk drive
Remove unused programs
Install and run antispyware software
Disconnect unused network connections:
Click Start, and then click My Computer.
On the Tools menu, click Disconnect Network Drive.
Select the network drives that you no longer need, and then click[b] OK.
Stop Unwanted startup programs:
Start > Run > write msconfig > Click on StartUp tab
Deselect the programs you want to stop
If this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that made your system slow
Sep 28, 2013 | Lenovo ThinkPad T61 Notebook
I cant get into my acer one. Yantoo virus took over. wont turn on.. what do i do?
Boot to Safe Mode with Networking, download freeware MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the Trial Pro version, you want the freeware version. In Safe Mode with Networking, run a FULL scan, depending on the size of your HDD, it may take hours. Delete ALL results, reboot normally. Repeat if necessary. Use freeware CCLEANER: http://www.filehippo.com/download_ccleaner/ To clean/remove the junk from your machine. This freeware program has many useful tools. In the TOOLS section, select STARTUP , disable ALL unnecessary startup programs, this will speed up starts and running of your Laptop. For further assistance respond to this post.
May 23, 2013 | Acer Computers & Internet
I cant use my camera because its being used but another app... but i have no idea how to locate or close the app
I would suspect it in a startup program, say CyberLink. It's set to start at Windows Startup. Open the webcam software for your laptop and disable Start at Windows, OR download CCLEANER freeware at : http://www.filehippo.com/download_ccleaner/ .This is a good program to learn to use. You can clean the junk from your machine and in the TOOLS section, STARTUP, look for your webcam startup program, disable it. Disable ALL unnessary startup programs to speed boot and shut downs.
Jan 06, 2013 | Acer Aspire 5600U all-in-one desktop
I can not get my kodak hero 5.1 printer to work on my windows xp 64 bit
Turning sharing on or off
The first time you connect to a network, you'll be asked if you want to turn on sharing between PCs and connect to network devices such as printers. Your answer automatically sets the appropriate firewall and security settings for the type of network that you connected to. You can turn sharing on or off at any time.
To turn sharing on or off
  1. hh_ppeic.pngTap or click to view available networks.
  2. Press and hold or right-click the network you're connected to, then tap or click Turn sharing on or off.
    435600ef-5a98-4568-bfa2-28d51981b1e3_13.jpgMenu used to turn sharing on or off
  3. Do one of the following:
    • Choose Yes, turn on sharing and connect to devices for home or small office networks, or when you know and trust the people and devices on the network. This setting allows your PC to connect to devices on the network, such as printers.
    • Choose No, don't turn on sharing or connect to devices for networks in public places (such as coffee shops or airports), or when you don't know or trust the people and devices on the network.
      Notes
      • Turning sharing on prepares your PC for sharing files and devices on a network. For more information about sharing with other people on your network, see Sharing files and folders on a network or a shared PC.
      • The network sharing setting is only available for WiFi, Ethernet, VPN (non-domain) and dial-up (non-domain) connections. It's unavailable for domain networks. On VPN or dial-up connections, you must connect to the network first, then press and hold or right-click the network name to change the network sharing setting.
      • Turning on sharing changes your firewall settings to allow some communication, which can be a security risk. If you know you won't need to share files or printers, the safest choice is No, don't share or connect to devices.
      • Choosing No, don't turn on sharing or connect to devices blocks the following applications and services from working: PlayTo, file sharing, network discovery and automatic setup of network devices.
About network discovery
Network discovery is a setting that affects whether your computer can see (find) other computers and devices on the network and whether other computers on the network can see your computer. It's one of several settings that are turned on when you turn on network sharing. You can turn network discovery on or off independently of network sharing, but we discourage this. Here's why. If you're connected to a network in a public location and you decide to turn on network discovery but leave network sharing turned off, the network discovery setting will be on for every public network you connect to from then on. This wouldn't be safe. That's why we recommend using the network sharing setting instead.
However, if for some reason you need to turn network discovery on or off independently of the network sharing setting, here's how to do it:
  1. hh_ppeic.pngTap or click to open Advanced sharing settings.
  2. Tap or click the chevron 7d2e0f87-bcfb-44a3-8422-5c9353bcde11_89.jpg to expand your current network profile.
  3. Tap or click Turn on network discovery or Turn off network discovery, then click Save changes. 1f9463c2-c968-47bf-9b4d-939c5d1af477_70.jpg You might be asked for an admin password or to confirm your choice.
Jan 07, 2012 | Kodak Office Equipment & Supplies
I'm playing a game that uses tab key a lot. The dvd hotkey is right next to the tab and it tries to load that over my game. How can I disable that hotkey. The program came with the computer and I...
Uninstall the hotkey software from Control Panel (Add/Remove Programs in XP, Programs and Features in Vista, 7)
Alternatively install Startup Control Panel and uncheck the program from startup.The program works great in XP, for Vista and 7 there is more playing around:
  • Download the zip file
  • Click Extract All files
  • Right click on the program
  • Choose Run as Administrator
  • Install the program
  • Open Control Panel and choose Classic View
  • Run Startup
  • Uncheck something in HKLM and it will duplicate
  • Close Startup
  • Wait for Windows to pop up a box
  • Click Reinstall using recommended settings
  • Allow the program to run
  • Now you can remove the programs from startup.
  • Restart your computer
Jul 23, 2011 | Computers & Internet
My dell studio startup repair cant fix the problem,every time i start my pc it goes off after the startup repair
Try booting it up in safe mode. At the startup continuosuly press the F8 key repeatedly
Once you get to the Bootup option, select Safe Mode
After booting into safe mode, click on Start, All Programs, Accessories, System Tools, System Restore.
Restore to the date around when your laptop was working ok
Feb 25, 2011 | Dell Studio 17 Laptop
Can't get a wireless connection from my Linksys WRT54GC router
I think you have the router setup to not broadcast the SSID. Go to your router settings to change this option. By not broadcasting, it enhances security for your wireless network, because it looks like there's no network. I hope this helps!
Jul 15, 2009 | Linksys (WRT54GC) Router
Will not open,then can't turn off
Try starting the PC in "safe mode (with network support) " by tapping the F8 key whilst it boots up and selecting safe mode from the menu. (Which bypasses your start-up items) If this boots up ok then the problem is a program that is starting up with windows, Check the start menu / programs / startup for any programs and remove them.
You can then downlaod a free program called "Spybot search and destroy" - run it, select "mode / advanced" - Tools - Startup and remove the offending item!
Apr 28, 2009 | Computers & Internet
Acer Extensa 5420-5687 Notebook Logo
32 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
