-2002 Olds. Intrigue GL-
Was "told that I couldn't change the bulb in brake light in trunk/spoiler, have to replace the whole unit at $150(+/-) for parts". Can this be true?
https://www.spoilerlights.com/spoilerlig... I just came across this today.https://www.spoilerlights.com/spoilerlights/oldsmobile-intrigue-spoilerlight-type-sl-2836rd/
You can't post conmments that contain an email address.
you can use one of the wires from either brake light and make yourself a good ground in trunk and running the two wires to you light switch. be careful where and how you run wires around the trunk hindges as you do not want them to become pinched and short out as that is a safety issue and get you pulled over. always solder and heat shrink all splices and wire to wire connections, if you dont you will hate your self later as wire from front of car to back of car could then need to be replaced.
There are usually two ways that these lights are mounted. One is under the light through the trunk. Another is just popping the plastic cover over the light off. It slides back. In some cars in others, it has a screw.
This is a simple bulb replacement.Simply pop off the access cover(if you need to) then twist the bulb in a counter-clockwise motion to remove it.Install is opposite of removal.I hope I could help, rate me accordingly, Thanks.
In the trunk, in the rear corners, you'll see some plastic "caps" with tabs on them, similar to wing nuts. Remove those, and the taillight comes right off the back of the car. That will allow you to replace the bulbs.
Rats! Thanks.
