LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Constantly getting write data to media errors
It appears as though every time I try to backup a large file to my LaCie 1000GB hard drive I get an "error on a request to write data to media" error message. I am unable to do a complete backup for any of my existing folders. I am using the MS Disk Backup utility provided on my Windows XP system. I have already reformated the disk drive and even played with the virtual memory settings, but the error still occurs. Before this, I had a 250GB Western Digital hard drive that worked fine until it burned out. Is it the hard drive, or my computer, or do I need another backup application?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
233
Points
SPhynkter;
Shouldn't both drives be the same? Can you place a fat32 file format onto a NTFS
format? I would think one could not read the other.
Any further ideas.
J Heintz.
Anonymous
Level 2:
  • Expert 221 Answers
  • Posted on May 11, 2009
Anonymous
Expert
Level 2:
Answers
221
Questions
0
Helped
117125
Points
734
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
1helpful
I have a Lacie wireless space network drive (1TB) connected directly to my router. I'm only using the switch functionality and have my pc connected to the internet through one of the 3 ports on the...
Here is what LaCie suggests about this issue:- first backup any data you have copied on Wireless Space. You can also backup your configuration: from "configuration" tab of "Support" widget, click "save" button next to "Configuration file", it will download a backup file.
- still in "configuration" tab of "Support" widget, tick the third box labeled "Restore device to factory state (data erased)", or any equivalent quote in selected language, and click apply
- the device will reboot, rebuild hard drive image, then reboot on default state. The issue is definitively fixed
- it is recommended to apply latest update downloaded from LaCie website
- you can restore previous configuration in "configuration" tab of "Support" widget, click restore and select previously downloaded backup file
tip
How back up your files (data) before doing system restore
<p>1. Use of pre-installed backup tools. Many computers have a backup software installed when you buy (including Time Machine backup and restore for Mac or Windows). These tools are designed to transfer files to various media they create on the computer hard drive or external hard drive, you can prevent a total loss of data is performed. When you open the utility, follow the onscreen instructions to complete the backup. <br /> <p><br /> <p>2. Back up important files on a USB stick or Memory Stick. Insert the stick into a USB port on your computer. Drag the selected files to the disk icon on the desktop (Mac) or PC (Windows) will appear. Flash drives and memory sticks are very mobile and can be stored in small spaces such as basements. Although they generally do not have a capacity of more than a few gigabytes (GB), they are large enough to store your important files. <br /> <p><br /> <p>3. Enter an external hard drive. These external hard drives usually have a very large capacity and can therefore keep most or all files on a disk. Connect the external hard drive via a USB port. You can drag and drop files on your hard disk or use it as a means of backup using a backup utility installed. <br /> <p><br /> <p>4. Burn your important files on a CD-R or DVD-R. an entire hard disk backup can be many slices, so this option is ideal if you want large media files or documents for easy access later. Insert the CD into the CD-ROM and follow the instructions on the screen (for Windows and Mac) to back up and store files. <br /> <p><br /> <p>5. Upload files for storage in the cloud. Services in the Internet cloud storage (like Mozy and drop-down box) are great ways to backup files to the internet access from any Internet enabled device. Important files with sensitive information may only be attached to a back-up cloud services such as Mozy. Clouds, Drop box is ideal for backing up photos, videos and other files less sensitive.<br />
on Jun 21, 2011 • Computers & Internet
Lacie ext hard drive, 500 GB, doesn't show files but 123GB used
you can always recover your files with the program undelete . exe
verry good working tool.
if you are interested
2helpful
2answers
Lost my data from my imac drive trying to backup to my Lacie.
yes U can recover it... plz download the registered version from the torrent site of software know as DATA DOCTOR RECOVERY .. this software will help you getting back you Data if you did not formated the Hard drive.. thank u for asking Question..
My LaCIe external hard drive will not open - I get a message saying that the disc is not ready and there may be a drawer open as though it is a DVD ROM - I have tried it on 3 diff computers and the message...
I am not really sure where to start here because I am a little confused about your setup here. It seems you made a great choice to keep Windows and your data on separate drives. Your primary hard drive is a really fast SATA Raptor drive, which is great, but I would never use an external hard drive for general everyday data storage. Many will probably disagree with what I have to say, but external hard drives should really be used only for temporary backup. I would never suggest using an external hard drive as your only copy of your data or for regular everyday use. There are several reasons for this:
1. External Hard drives are generally slower than Internal Drives.
2. Many of them come preformatted with Fat32, so you are limited to files no larger then 4gig.
3. They are more likely to fail because they are normally subjected to a greater likelihood of accidental bumping or dropping.
4. Many external drive enclosures are not properly cooled for continuous usage and thus lead to premature failure.
5. You often have no idea what brand of hard drive is actually inside the enclosure.
Don’t get me wrong, external hard drives are wonderful and I use them all the time. I have three LaCie 160 gig drives myself that I use all the time for temporary backup, but I rotate them so that I have 3 consecutive backups and would never use them (not just Lacie but any external drive) as my only backup or as a primary data drive. And yes, I have had to replace a few of them due to failure.
So to address your specific questions:
What went wrong?
1. Bad Cable - Well it is probably unlikely, but I would first try another USB cable just to make sure the cable is not damaged.
2. Power Supply - Try another power supply if you have or can borrow one.
3. Controller Failed – The Controller inside the Lacie has failed.
4. Drive Failure – The Hard Disk inside the Lacie has failed. Drives typically have an average 5 year lifespan, some last longer and some can fail much sooner. Unfortunately, you rarely have any warning, thus the need for backups.
2answers
Sync software/empty folder/ slow backup/
hello frustrated one,
the back up feature is application dependent, not hardware dependent, misfortunately. Gotta love sales guys.
my understanding is that these will back up data files, not application files.
backup speed is dependent on how it's connected. in ascending order.
USB 2.0
Firewire
Ethernet
simple situation..just need to know what your connecting with.
Also, you may want to consider an online backup utility, as well. I use one from here
1helpful
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
2answers
Lacie hadr drive problem
I am looking for some help with the same problem with a Lacie External Hard Drive, does anyone respond to these posts?
2answers
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
