Question about Avanquest My Invoices & Estimates Deluxe (804526031483)
I keep getting Data saving error: Save Entity Exception on a estimate
1 Related Answer
David Bottomley
  • 388 Answers
SOURCE: I get an error code
ok you have to create a file with all the compay details try looking for a set up wizard.
thats the best i can offer as im not 100% oncertain types of software.
Posted on Oct 06, 2010
Data saving error
Per Avanquest: We have found out that this randomly happens due to an interruption in saving the data in MyInvoices and Estimates Deluxe version 10. We recommend that you do the following steps:Go to the Task Manager.On the Applications tab, click on MyInvoices and Estimates.Click on End Task.Relaunch MyInvoices and Estimates.Create a new invoice/estimate and save it.
If that fails to resolve the issue, you should also try the following:
Close MyInvoices and Estimates.Restart your computer.Relaunch MyInvoices and Estimates.Create a new invoice/estimate and save it.
Note: The task you need to end is MIED.exe
May 23, 2014 | Avanquest My Invoices And Estimates Deluxe...
Tip
Solutions for exception Processing Message c0000a3 parameters 75b6bf7c 4...
Many of you might have faced issue called windows – drive not ready and a message ” exception Processing Message c0000a3 parameters 75b6bf7c 4 75b6bf7c 75b6bf7c” right below of that. It will keep disturb you every now and then even if you close this number of times This normally happens when you remove a drive like Floppy drive, CD Drive or Pen drives from its working conditions without proper instructions. You will get this error message when you remove a CD/DVD from CD/DVD drive during a process happening form CD/DVD like installing software or accessing files etc.
In that situations the programs seeking the files from the drives but its not finding there.So we are getting this error.
You can see the error below.
Here is the steps to solve the issue:
a) Simply put a CD/DVD in to the CD/DVD drive and click on Continue.
b) Open the CPU box and make sure all the data cables connected properly.Like data cable for Floppy drive and CD/DVD Drives.
c) Go to BIOS and disable the Drives which you are not using. Nowadays mostly nobody uses Floppy drive. So you can disable Floppy drive. You can disable unused IDE or SATA ports in bios.Save the settings and restart your PC, Now you will not get the annoying pop ups now.
on Jul 03, 2010 | Computers & Internet
I have an error message on My Invoices & Estimates when trying to save an invoice data saving error: Save Entity exception. It wont let me save it or back out of it... What do i need to do to correct...
  1. Go to the Task Manager.
  2. On the Applications tab, click on MyInvoices and Estimates.
  3. Click on End Task.
  4. Relaunch MyInvoices and Estimates.
  5. Create a new invoice/estimate and save it.
  1. Close MyInvoices and Estimates.
  2. Restart your computer.
  3. Relaunch MyInvoices and Estimates.
This worked for me without losing any data other than the invoice I was creating. Always make backups so if your data file is corrupted, you can easily restore it. Hope this helps.
http://support.avanquest.com/support/solutions/articles/1000173898-when-saving-an-invoice-or-estimate-i-get-a-data-saving-error-message-how-can-i-correct-this-
Dec 06, 2012 | Avanquest My Invoices And Estimates Deluxe...
I am working on doing a fresh reinstall on a computer for someone, but they need me to save thier "My Invoices & Estimates Deluxe" information & reload it on the computer once I restore...
You have to backup all the require data to an external storage media first. If your are not familar with the software data backup. Ask your principal help or the person who operate on the system, to backup their vital data for to the external storage media, because you don't know which files are important.
Once you have install the OS, On installing "My Invoices & Estimates Deluxe" make sure the name the company file the exact same as the back up file name. If not you will not be able to load the backup files ie. you get errors opening the backup files.
Hope it helps.
Nov 22, 2010 | Avanquest My Invoices And Estimates Deluxe...
I get an error code when trying to complete the install of a new business. The error code reads; Create Company File Error, Exceptions: Save Entity Exception. I have windows xp, and I turned my antivirus...
Oct 06, 2010 | Avanquest My Invoices And Estimates Deluxe...
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
Data saving error
I came to the point where I had done everything, restarted, closed the program in the task manager nothing would work. Every time I would hit any key even the X to close the program I would get the error. data saving error enitity exception. So finally I shut down the computer, disconnected the battery, waited about ten minutes started back up and so far it has worked without problems. Ever since My Deluxe Invoices made their last up grade I personally have had lots of issues with the update. Wish I could go back to one of the very first versions but with the ability to email statements. Thats the only upgrade I have found useful.
Dec 27, 2009 | Avanquest My Invoices And Estimates Deluxe...
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
What does error 8011038b stands for?
Try backing up whatever data you want to keep, then reformat your memstick.
Feb 24, 2009 | Sony PlayStation Portable (PSP) Console
Avanquest My Invoices & Estimates Deluxe (804526031483) Logo
1,395 people viewed this question
Top Avanquest Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Sheldon Dedek
Bill Boyd
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
