Question about Honeywell TH4210D1005 Heater
My Honeywell TH4210D1005 Thermostat will not respond
I recently moved into a new house where we have a Honeywell TH4210D1005. I read the manual and followed the directions on how to reset the system to the default (most energy efficient) 5-2 day program. It's 2:30 PM and it is currently 62 degrees outside - my thermostat says that it is set to 62 degrees, but it is 69 degrees in the house. Why is the actual temp different then the set temp?
Posted by shaun_flaher on
Anonymous
    New Friend:
  • 92 Answers
Well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Posted on Apr 07, 2009
Honeywell Instruction Manuals
Visit this link for a full manual.
Oct 17, 2013 | Heating & Cooling
I need a user manuel...thank you
Here's a link ...... http://www.honeywell-thermostat.com/manuals/th4210d1005manual.pdf
Mar 28, 2011 | Honeywell TH4210D1005 Heater
House is freezing....cant reset unit...says cool instead of heat...internal schedule all messed up.....says its friday
For temporary heat while you shop for a new thermostat, take the wire off terminal R and cross it with the wire on terminak W. This will start heat cycle and will run as long as you have the wires crossed. Do not keep wires crossed more than 10 minutes each time you do it.
Jan 23, 2011 | Honeywell TH4210D1005 Heater
Need to change batteries. How do you open it up?
here is the owners manual for that unit. it shows to push a button on the bottom of the unit to remove from wall plate. hope this helps.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1760EFS.pdf
Dec 21, 2010 | Honeywell TH4210D1005 Heater
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
Need to program thermostat for air conditioning
well your system should automatically shut off when the thermostat reaches temperature, if it doesnt, then you need to look at possibly replacing the wall thermostat or the thermistor on the unit
Aug 17, 2009 | Honeywell TH4210D1005 Heater
Honeywell TH4210D1005 Heater Logo
701 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Sean
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
