Sony Cyber-shot DSC-W30 Digital Camera Logo
Question about Sony Cyber-shot DSC-W30 Digital Camera
I can't zoom in, i have to turn my camera off and on again and still it doesn't work
I haven't dropped my camera but it has had a few little bumps too it :-/ at first the lens would go in and out then id have to turn it off and on again..but that was fixed with a little tug at the lens (i was gentle) but now when i try to zoom into a subject nothing happens then the "turn off and on again" error pops up, even after i turn it off and on again nothing seems to be fixed..everything else works great, i just can't zoom in on anything..please help!
Posted by dunnowhat2do on
Anonymous
Hey.. my namee is Mercedes.. and my camaraa feell on the rode and the went over it.. and the only thng that dosnt work is the zoom in and the flasher... i calld the sevrice but they siad it cost more trhen the camara if yu repair it. What should i do?
Posted on May 17, 2008
Anonymous
at first the lens would go in and out then id have to turn it off and on again..but that was fixed with a little tug at the lens (i was gentle) but now when i try to zoom into a subject nothing happens then the "turn off and on again" error pops up, even after i turn it off and on again nothing seems to be fixed..everything else works great, i just can't zoom in on anything (camera,photo..)only play..please help!
Mr Dung mail: [email protected]
Posted on Jan 12, 2008
  • Anonymous Jan 12, 2008
    sony cyber-shot DSC-W35
Anonymous
    Problem Solver:
  • 36 Answers
Your lens assy needs replacement, thanks
Posted on Sep 06, 2007
3answers
Zoom Error
try a camera reset first of all.
if not,thanit is little what you can do,because your camera is  acompact one..you just cant get into it.
Try a specialized service because the problem can be solved by replacing the zoom engine if it is brocken.
if it is a lense problem..wellthan is more complicated..
good luck
Manual zoom does not work when I try and use it
Most likely the motor mecanisim was damaged when you dropped it. was unable to locate a sony dealer in nepal, You could try Sears if there is one in nepal.
Hope that was helpful.
The rocker zoom in and out on the top has frozen and doesn't work suddenly :(
I think focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2011 • Cameras
6helpful
Zoom did not operate normally,insert the battery again and turn camera on again Camera doesn't operate normally
Hi had this problem with my WB100. Zoom would come out then pop back in and say zoom nit not operate normally, please put new batteries in and try again or contact bla bla. What i did when the zoom popped out is i held onto it and didnt let it retract back and turned it back on. It worked after that so i guess the zoom must of been a little forced in when it was in use last in when turned on it wasnt fully going forward. Worked for me so worth a shot
17helpful
4answers
System error: zoom message with Panasonic Lumix FS15 camera
I had the same problem, i switched the camera on in capture mode and zoomed in and applied a little pressure to the lens which made a slight click but retracted and has worked fine since. I may of just been lucky but the camera is fully functional again, could be worth a try.
9helpful
Zoom lens is stuck on my camera
Hey, my husband just fixed it! You just wiggle/bend the zoom lens, and you feel a "pop", and then the zoom retracts and you're fine! I was afraid to "break" it, but someone on vacation had the same problem and told him this solution a few weeks ago. So don't be afraid to use a little force-at least, in our case, it worked! Good luck.
1helpful
Zoom error
You lens are tilted? If so, they are out of track. Maybe you bumped or dropped the camera. Try straighten them up with your fingers, very gently.
17helpful
7answers
Focus/zoom issue with Konica Minolta Dimage Z3 digital camera w/ 12x zoom
This is a symptom commonly listed for DiMAGE cameras listed on EBay for 'parts only'. Dropping the camera I had caused the same problem and carefully 'smacking' the camera once again did solve the problem but that may have been dumb luck. Sorry but it is a service task that may cost more than the camera.
2helpful
Picture still blurred on record mode
Your problem sounds like a focus problem. Could be that it's on manual focus and you're hitting the sweet spot only in full zoom? From the manual: 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button.  M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus.  Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again. Hope it works out, let us know!
Top Sony Cameras Experts
Marvin
Marvin
Are you a Sony Camera Expert? Answer questions, earn points and help others
