The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Error code HS-01
