Question about Yardworks Broadcast Spreader Walk Behind
I have a Yardworks model "C T0059-SPWC" Broadcast Spreader. The part named "Flow Control Box", (controls the amount of flow from hopper)is damaged beyond repair. Where may I obtain this part?
Posted by John Harrod on
Thomas Smithbrother
    Top Expert:
  • 3,698 Answers
Searsparts. com
Posted on Jul 06, 2014
Where can I get parts for yardworks model ct0059-spwc lawn fertilizer walk behind spreader? It is #85 capacity.
probably have to buy ( if able to get parts ) the whole box which constitutes the cost of a new unit
just an idea if you cannot get parts from the manufacturer
go google and type in ---how to weld plastic--
there are youtube s that show how easy it is to repair plastic objects and how to reinforce high load areas so that they do not repeat break
just a thought as it is really easy after a bit of practice and saves money
Nov 24, 2015 | Cars & Trucks
I have an older scotts drop spreader, called a precision flow control model and do not know what settings to use with the Scotts turf builder I have purchased.
The best way is to just place a small amount... like 5 lb in the hopper...start with it barely open and see how far you get,,, then compute from there what you need...
The settings they give you are guesamates at best and are often set to place too much... why not??? they are selling you a product!!
heatman101
May 09, 2011 | Scotts Company Scotts Turf Builder Classic...
I have an old Jackson 36HSS-26 lawn spreader. What setting should I use for various materials? I am about to spread some Scotts Turf Builder with Plus 2 weed control.
It should say on the back of the box or give some indication as to the settings but in general you can gague it from the flow rate and or the granual size but a rough setting is about 5 to 6
Jul 12, 2010 | Jackson 24" Pulltype Lawn Spreader Model...
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
I bought a agri fab 175ib spreader and did not get instrution
Hello, Wharrelson65 -
Unless another Fixya.com member has uploaded a manual for your model Agri-Fab spreader, right now, it is not available through Fixya.com.
This is the link to the Agri-Fab company web page with manuals for their products:
http://www.agri-fab.com/Utilities/Support/Manuals.aspx
(Copy and paste the web address into the address box of your browser.)
Note: I tend to try to find a company's home page and then try to find the link for Support, Customer Service, Parts in order to see if a manual is available to download.
By the way, do you really want many others whom you do not know to have your email address? If not, I suggest you use the Edit feature and remove your email address from your question.
Jan 13, 2018 | Agri-Fab 175lb Agri - Fab Tow Broadcast...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Flow control lever doesn't open hopper door
your fertilizer is got clumps in it. I have experienced the same when using TSC fertilizer (cheap and wet).
Mar 22, 2009 | Agri-Fab 175lb Agri - Fab Tow Broadcast...
Yardworks Broadcast Spreader Walk Behind Logo
959 people viewed this question
Top Yardworks Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
