AUDIO VOICE IS NOT COMING
Which operating system and Desktop or Laptop computer ?........
Desktop
If your computer came with a
motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device
manager scroll to sound video and game controllers you might see a yellow
question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and
audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio
you will find 3 drop down lists make sure you have selected the correct speaker
settings.
Click start control panel sounds and audio devices select advanced there might
be a tick in the mute box untick it
If this does not fix the problem
audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the speaker volume icon system select adjust volume.
audio volume advanced speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand system speaker right click properties then select use this device
(enable).
The speaker plug/outlets is usually
at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the
rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust
using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU
central processing unit.
Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a
search tab just type in what you are looking for.
Tick in either the all software or
windows software box
IE: motherboard name audio driver
you might have to try a few times to get it right
for windows 7
Click start right click on computer
select properties then device manager scroll to sound and video game
controllers if you see a yellow question/exclamation mark or a red X the driver
will need to update drivers.
select properties then device manager scroll to sound and video if you right
click on sound and video then on high definition audio device select update
driver software.
Click start control panel hardware
and sound manage audio devices right click on your speaker select configure
speakers.
Right click on the speaker icon in
the bottom taskbar you will see an array of options select
playback devices make sure it
has a green tick and the correct speakers are selected
be updated if you computer came with
a motherboard disk the drivers could be on it although
once speakers are connected widows 7
should automatically update the drivers.
and sound manage audio devices playback you might have to set a default go for
via high definition audio then right click on speaker.
You might have to configure them
then select properties you will see tabs general level in this tab make sure
your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
Laptop
settings.
be a tick in the mute box untick it.
If his does not fix the problem
audio devices you can adjust the volume there also select speaker volume.
You can change your settings there
you can also tick in the box place icon in taskbar for any further volume
control settings you will need to right click on the speaker volume icon
from the drop down list or navigate
to the device manager scroll to system devices + to expand system speaker right
click properties then select use this device (enable) also you might check the speaker
plug/outlets they are usually at the side of the laptop.
the rear of the input plug make sure
dust causes static to build up in a computer
on the home page you should see a
for windows 7
driver software
speakers.
be updated.
If you computer came with a
You
might have to configure them then select properties you will see tabs general
level in this tab make sure your settings are loud enough also enhancements and
advanced from the drop down list in the advanced tab select dvd quality or another
then apply
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a
free driver solutions
which will automatically search for and find the
correct driver
You
will have to update every driver individually once you update you might be
asked whether you want to restart or make a system restore point.
Click
no to both of these then continue updating each driver free then restart once
all of the drivers have been updated.
It might take some time being free
SOURCE: audio drivers needed
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
132
SOURCE: mercury 945 motherboard audio drivers
if you have any chipset board of 945tryit. Some time we can use diffrent board as bio star, mercury.msi, but serius should be same. the can support for vj.sount etc.....
SOURCE: pentium4 mercury motherboard audio,video drivers
hi, i m tajinder, and can u tell me how can i download {system model : - (MERCURY AWRDACPI)} drivers...
SOURCE: didn't get audio driver for kvm800m
Try these direct from realtek
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
SOURCE: I WANT AN AUDIO DRIVER FOR PVCLE266M-L V3.0A
You can download the drivers from this link
http://www.mercury-pc.com/product-drivers.php?productid=439
Download it, install it and restart you system for the changes to take place.
