Panasonic SC-PM08 Shelf System Logo
Question about Panasonic SC-PM08 Shelf System
Panasonic sa pm45 error code f76 - Panasonic SC-PM08 Shelf System
3 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Panasonic SC-EN17. F76
you wil have to subtitute a tech for a dealer instead.they will be able to help check along the left side of the home page for fixya and try to locate a repairman near you just put in your area code.good luck.
Posted on Apr 06, 2007
ravichetty
RAVI CHETTY
  • 158 Answers
SOURCE: fault code for sa ht 17
Hi,F76 is the error displayed when the fan goes faulty in the unit.
Posted on Aug 19, 2009
Anonymous
SOURCE: Fehler F76 beim SA PM
there is a problem with the cooler we had the prob too .
Posted on Nov 10, 2012
1helpful
3answers
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
1helpful
Sa-100bt i have an f76 error after taking unit apart i have found that there is a black wire next to where the fan plugs in this wire has been disconected does any one know where it goes thanks
Usually that is just to wrap around the fan cable to make sure it doesn't go into the fan. F76 error can be either the fan is not turning, or the amp is bad.
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
9helpful
2answers
Fault code for sa ht 17
2answers
My Panasonic SA pm08 DVD/CD player is stuck on 'Locked' and I can't change the cd's or do anything. J How do I unlock system?
Try first unplugging unit from main, and holding the cancel button.
If that does not work try the following:
Hold at the same time the stop button on the main unit and key >10 on the remote control at the same time for about 5 seconds, until you get the word "initialised" on display. This will reset the unit to factory settings.
2answers
10helpful
6answers
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
Top Panasonic Audio Players & Recorders Experts
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
