Question about Humax Hdr-Fox T2 500Gb Freeview Hd Digital Tv Recorder
I am getting a error message when I press TV Portal button. Why is this? I cannot get rid of it.
Posted by holden222 on
Artie
    Champion:
  • 236 Answers
Restore factory settings (if you can) and start from the beginning.
Posted on Nov 14, 2013
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
I have a Palm Tungsten E. Whenever I try to hot sync there is always this error message as follows; An error occurred in the application you are using Note the error code and contact the developer of this...
The Graffiti and the Backlight applications are not compatable and must be deleted.DO a hard reset (Press power button and reset until the Plam Logo screen shows, press up button - this brings you back to original factory setting, and potentially undoes all the stuff you did when trying to make the thing work), synchronize, hit home icon, press menu button, select delete, find Backlight, hit delete, find Graffiti, hit delete, and sychronize again.
Oct 12, 2008 | Computers & Internet
I've recently purchased a DLC32SMART and i've connected it to the internet and it works fine as i watched youtube on it, but when pressing the internet portal button it takes me to what looks like a s
Back where you purchased it from and ask same questions. Some TV made these days are multi language ready and this sometimes create local problems with language barriers. Alternatively, check if the store has a display TV and see if it has the same problem. I do this all the times and the store staff are helpful, even if I have no idea what some things mean in another language, they can solve it.
Oct 18, 2014 | Digihome LCD TV
HOW DO I GET RID OF THE SQUARE MESSAGE BOX?
Press the "CC" button on the remote control once.
Aug 27, 2012 | Sony KV-36FS100 36" TV
Auria tv "button locked" message.
Holding Vol and Vol- buttons will lock/unlock the buttons. In my case, this didn't completely fix the problem - I was not able to get to many functions. I suspect it was in some store-demo mode. To completely rest, hold the Menu and Chan- buttons then press the Power button (starting from the tv being off). Pressing other button combos will put the tv into manufacturing mode (with cycling solid colors). Turning the tv off and back on will exit this.
Jun 24, 2011 | Televison & Video
I get the message : error 1700 and want to get rid of it .
Pixma IP2000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
It is undertaken from service manual.
Mar 09, 2011 | Canon PIXMA iP2000 InkJet Printer
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Espon 320 stuck with service required error message.
There is no button pressing sequence for this printer Epson got wise to that one.However check this out for a resolution.
http://www.wasteink.co.uk/epson-ipr-reset/
Sep 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Turn on tv get error message Lamp needs to be replaced and the Lamp Hour meter needs to be reset. I still have picture how do I reset this error message
Howdy,
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Mar 25, 2009 | Panasonic PT-44LCX65 Television
Caller id
see if this corrects the problem. . .press and hold menu/voice mail button to enter the menu. . .press the zero/oper button to go to the message waiting programming option. . then press the edit/flash button to reset tne Message Waiting Indicator. . "DEL" will begin flashing..press the redial/save/ pause button to delete this indicator.. . a long beep will sound to confirm a reset/removal of notification..press menu button to exit. Theo
May 31, 2007 | Xact Communication XG2206 Cordless Phone
Humax Hdr-Fox T2 500Gb Freeview Hd Digital Tv Recorder Logo
140 people viewed this question
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
