Hello, My plasma 1st developed one 2 inch thick (blue) wide line that runs from the top to the bottom of the screen. Now it has a second line (yellow) that does the same thing but on the other side of the screen. I called LG who told me to unplug it but it did nothing. Should I bother taking it in or is it shot?? Thanks!!
The lines are thick and across the screen. then the televsion turns off. the lines apear after about an hour of it being on. it happends no matter which input i use. its only 14 months old. sorry havent found any solutions that aren't expensive or above my technical skill
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Both of the lines are transparent. At first the line would come and go for no real reason but now the blue one seems to stay on all the time but the yellow on will come and go. No solution yet.
