I need to make a RS232 cable between two componentes of avionics comunication system, but i dont know which are the appropriate wires to use for. Thanks
Hi, according to picture, these devices communicate by a serial port (RS-232) maybe host COM port settings are changed and therefore cannot communicate with the source of data (i.e. a server).
The manual for the RuCo VX1000c is available at http://www.aboutprojectors.com/pdf/runco-vx-1000ci-manual.pdf The RS232 codes and protocols are towards the back of the manual. According to the manual, the PFP connects to the projector using a CAT5 cable.
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
You need another cable (the metrologic cable doesnt work with the same configuration) and set the button in the interface card to rs-232 and program the scanner-scale with the programing tags.
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following: DB-9 RS-232 Serial Connection or DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following: DB-25 Serial Connection or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
