Question about Cecilware Coffee Makers & Espresso Machines
Cecilware espresso - Cecilware Coffee Makers & Espresso Machines
jasbo
  • Cecilware Master
  • 2,239 Answers
What's your question?
Posted on Jan 28, 2015
Cecilware fms40 fryer convert to lp gas
Most NatGas devices will convert to use of LP by changing the orifice.
GRINDMASTER CECILWARE F177A ORIFICE 52 1 16 LP GAS
Oct 05, 2015 | Cecilware FMS-40 Deep Fryer
Water will not dispense from my cecilware cappuccino machine but the motor works fine
unplug it for 20 seconds and plug it back in. this will reset the solenoid board. if it still doesn't, see if the solenoid valve clicks at all. if not, replace the solenoid coil.
Nov 13, 2013 | Cecilware Coffee Makers & Espresso...
I have a Cecilware EL250 deep fryer that starts to heat up and stops. I feel it needs a new thermostat. What is the thermostat model number, how much does it cost, and where can I buy it. I live in...
Hi there.
You will be able to find the nearest authorized parts and service dealer in your area when you visit http://www.grindmaster.com for your Cecilware Fryer.
Feb 18, 2011 | Cecilware EL-250 Deep Fryer
Hi I have got a cecilware deep fat fryer
Sounds like you need a gas regulator in the main line.
Either that or you are using a natural gas fryer on propane which is a no-no if not converted properly.
Dec 20, 2010 | Cecilware FMS-40 Deep Fryer
Basket with coffee and filter overflows. Why?
Grounds might be too fine or not leveled before brewing, sprayhead might be dirty and clogged.
Jul 02, 2010 | Cecilware APT100WT Coffee Maker
Cecilware fme40 propane model .flame is soft. what
Hi there.
For propane gas fryer the incoming gas pressure must be 11 to 14" w.c. and the manifold gas pressure must be 10"w.c.
Regards.
Mar 17, 2010 | Cecilware FMS-40 Deep Fryer
I have a ceceilware cappuccino machine GB5M and want to know if we can pour water in or pump it manually from a 20 litre water bottle.water line is being shut down for winter but still want to use the...
You should be able to use a booster pump like a Shurflo or other type pump, just make sure that it is not putting out more pressure than recommended by the machine manual.
Oct 09, 2009 | Cecilware 3K-GB-LD
Coffee Makers & Espresso Machines Logo
114 people viewed this question
Top Cecilware Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Cecilware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
