SOURCE: ECS P4M900T-M2 Motherboard windows xp service pack 3 audio driver
are you all running vista or xp ? if xp this sound chip will only work with sp1 installed as it is designed for vista
SOURCE: audio driver
http://download.softpedia.com/dl/67726aafea796ee43af7c61c08816bbc/4a479ec8/100030373/software/system/info/everestultimate502.exe
<<download this then get back to me once you have installed it
SOURCE: I CAN NOT DOWNLOAD THE DRIVER FOR ECS P4M900T-M2
Try EliteGroup support for your product: (under Downloads, click on Driver - choose the correct driver for your operating system)
EliteGroup P4M900T-M2
SOURCE: i want ecs p4m900t-m2 motherboard dirver
You can find all the necessary drivers from this link.. http://downloadnew.org/list/ecs-p4m900t-m2-v10-audio-driver/, check out the site slowly, you may skip something. All drivers are free. Good luck.
SOURCE: i already installed my sound
hello,
Check the following,
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx
For another check follow the Steps:
Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers).
So please go there website>supports>download or type mobdel no and search
For download
http://www.ecs.com.tw/ECSWebSite/Product/Product_Model.aspx?CategoryID=1&TypeID=32&MenuID=16&childid=M_7&LanID=0#Socket%20775
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
