Question about Yamaha Electrical Supplies
Yamaha 1000 generator smoking bad when running, why? I changed the oil
3 Related Answers
Anonymous
  • 76 Answers
SOURCE: 1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Posted on Jun 24, 2009
Joel Friedenberg
  • 1114 Answers
SOURCE: fipped over
This is a search and find type of problem. Check all wiring, especially if the generator has a low oil cut off switch. Check the wiring to that. Also, check carburetor linkage and for any springs that may have come off. Check the linkage to the governor on the engine to make sure the linkage is not binding.
Posted on Aug 10, 2009
Anonymous
SOURCE: oil change
Tip it over sideways - no drain hole exists, just the inlet.
Posted on Dec 24, 2010
What is the reason oil steaming in abundance ginrator yamahaef6000
If oily smoke is coming out of the muffler, then it is an indication that the rings are bad. Make sure that the oil is at the proper level.
Apr 30, 2015 | Yamaha Electrical Supplies
Should there be oil in the generator/stater housing? where can I get a break down of all parts to do this job I'm having a hell of a time! Please help???
Hi, You don't state what your actual problem is. Because it is normal for your Suzuki TL to have oil in this area. I run a 2005 Suzuki SV 650 N and a Yamaha TW 125. If you open the timing cover cap on the generator housing on these bikes oil is all over the place inside. The little Yam when changing the drive sprocket you have to drain the engine oil before removing the left hand crank casing. The generator and starter are housed here.
Jan 30, 2014 | 1999 Suzuki TL 1000 R
Oil light yamaha EDL5500
unplug it and see if the light changes if not ground the wire out if there is no change its wiring if it changes its a bad sending switch
Sep 04, 2012 | Yamaha Edl5500 Generator Oil Filter...
I've topped up the oil in a fzr 1000 exup with castrol, it started smoking, which oil should i use ?
OIL BRAND SHOULD HAVE NO INFLUENCE ON SMOKING UNLESS YUOU WENT FULL SYN. ON AN OLD MOTOR. IF YOU ARE TOPPING UP ARE YOU LOSING OIL?
Apr 18, 2011 | 1992 Yamaha FZR 1000
Can you help me? I have generator yamaha ef 2600. Generator normally running about 3 minutes then rpm comes unsteady and gen stops. Moreover at load 2kW gen immediatly works unsteady and stops. Without...
As you describe the problem, the reason is unstable load handling.
This means that the fuel or air is not enough.
When begin to be unsteady:
  1. If smoke comes out of muffler - the input air is not sufficient. Try to clean or change air filter (cleaner).
  2. If no smoke, the fuel is not enough. The reason may be the mechanical governor, or the fuel supply to it, fuel filter/strainer etc.
Aug 05, 2010 | Yamaha 2300 Watt Generator - EF2600
Fipped over
Aug 08, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
117 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
