Question about Samsung Televison & Video
Samsung plasma tv ps42b451b2wxxu has no sound when samsung bluray plugged in via hdmi
5 Related Answers
Keith Miller
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
David Low
  • 458 Answers
SOURCE: LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Posted on Apr 18, 2009
techbuster
INDIRA KUMAR
  • 5081 Answers
SOURCE: SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Posted on Jul 04, 2009
Anonymous
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
alexander404
alexander woolfolk
  • 276 Answers
SOURCE: Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
helpful hookup diagrams here: http://columbiaisa.50webs.com/diagrams_index.htm
Posted on Jul 05, 2010
I have a sanyo DP50740plasma tv a few years old. Last night I got wi fi and hooked up a Samsung blue ray player and the sound quit working. the picture is clear on dish (on HDMI 3) and the blue ray p
What happens when you take the bluray hdmi out? or turn the bluray power off from wall? can you connect audio from bluray with a separate cable? often one device overrides the other. there may be a way of daisy chaining the devices
Dec 17, 2014 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
No sound from tv. do I need an optic cable as well as the hdmi? HT-D5500 with a 55"Samsung plasma and a HD cable box
Your best hook up is going to be HDMI(out) from bluray and cable box to (in) on tv. The only thing you would need the optical cable for would be sound(out) to a reciever.
Apr 01, 2011 | Samsung Audio Players & Recorders
I have a z50p3 I tried to hook a samsung 1600
Sorry, man I have the same problem, with the same tv and player. Did you ever get a solution? LG Service Tech came out and his LG bluray player worked, whereas my Samsung didn't hooked to the TV. (It would spordically work going thru my HK254 AVR.)
He said either 1) the Samsung player was defaulting to a format that the Zenith being 3 years old could not decode (eg. 1080P) or that I might need to change inputs several times to get it to sync up or 3) by an LG Bluray player.
He said the Zenith was old and that newer sets are built with circuitry to help navigate the handshake easier. He couldn't find any service bulletins on it, and the one I got from LG he said didn't exist.
Feb 28, 2010 | Zenith Z50P3 50 in. Plasma TV
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
When hdmi cable is plugged in bluray player stops
Since it was stretched check the ontacts on the acutal HDMI connector on the tv and the bd player a pin bent or touching another pin will cause a vast amount of issues
Mar 29, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Televison & Video Logo
42 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
