Contributor
- Posted on Jun 06, 2016
Re: How do i replace bulb in juno air-loc recessed shower...
- Pull the trim ring away from the ceiling.
- Squeeze the springs on either side and slip them out of the u shaped tabs.
- Along the top of the trim there are 2 tabs that have a small ridge pointing inward. Squeeze those tabs so the silver bell of the trim slips though and can be pulled out horizontally. This is kind of tricky and takes some patience to get the tabs on both sides pushed at the same time.
- (Hint) Replace the bulb with a long life (LED) bulb. Since they are much cooler to operate you can probably put a slightly brighter bulb in and the darn thing will last for many years.
- Reverse the process to seal the fixture back up.
