Question about Bernina Sewing Machines
Using a bernina gold latch bobbin case on the Bernina 435 machine
Can you use the gold latch bobbin case to do free motion embroidery with the Bernina 435 or do you have to attach the embroidery module to use that bobbin case?
Posted by cvoskuhl on
  • Anonymous Mar 14, 2014
    Embroidery cases compatible wiyh 200 and 430
winserp
    Master:
  • 363 Answers
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
Posted on Nov 23, 2016
Anonymous
    Problem Solver:
  • 5 Answers
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Posted on Aug 15, 2009
  • time4me Jan 25, 2011
    There is indeed a Bernina 435--it's an anniversary model. I have it sitting right in front of me. And the bobbin does have a gold latch.
Bernina 820 bobbin case malfunction and thread caught on hook how can I fix this please?
YOU MUST HAVE TURNED THE TENSIONER DIAL, THIS IS THE KNOB THAT determines how tight the stiches are, what ever you did, try to turn the dial back a tiny but at a time after of course you put new needle in there and turn the wheel by hand only dont use speed pedal try that
Jul 02, 2018 | Bernina Sewing Machines
Bernina Deco 330 embroidery machine bobbin case tension.
There are tests to perform for testing and adjusting bobbin tension. There really aren't any "specifications" other than adjusting it until the bobbin drop test is where it is normally recommended.
adjust bobbin tension Google Search
P.S.--be sure to ALWAYS raise the presser foot when threading the upper thread to insure the thread seats completely in the tension disk.
Aug 22, 2016 | Bernina Sewing Machines
After cleaning the bobbin sensor, error message keeps coming on. What else should I do?
You should probably take it to a Bernina repair person.
https://www.youtube.com/watch?v=RHYwvv8lJ74
http://sewsabina.com/blog/?p=84
http://freemo.com/bernina-artista-730e/
Jun 23, 2016 | Bernina Artista 640E Sewing, Quilting and...
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
Bernina 1008 thread bunching on bottom
"Nesting or Rat's Nesting" on the bottom side of Bernina sewing machines (CB hook type) is generally the result of very loose top tension. If the problem is found in newer sewing machines such as machines made after 1986 (serial numbers beginning with 26xx xxxx), may have an older Bernina bobbin case in the machine. The problem with the older bobbin cases is that the rounded projection of the latch on the left side of the casing will catch thread, preventing easy thread escapement during the take-up lever cycling resulting in loops on the bottom side and or thread breakage, etc..
Note:....Timings and modified latch geometry's were applied to later models to allow for good thread escapement. Older Bernina cases cannot be used on newer machines but newer cases can be used on all CB hook Bernina machines.
Additionally, Chinese copies of the Bernina/Cerliani OEM bobbin are rampant and can cause sewing issues. Always ask for OEM Bernina cases.
Note the following trouble shooting logic:
1. The center tension disk that is visible through the thread slot in the top cover of most machines must be positioned exactly in the middle of the top cover slot. By loosening the fixing screws on the top tension mechanism, one can adjust the disk position to center.
2. It would be a very rare situation for the top tension to change whatsoever from the (red center marking) factory setting. The most likely cause of loose top tension under the normal center mark position, would be accumulated lint, thread, or a sticky substance between the disks. This would prevent the tension compression disks from applying an even tension on the sewing yarn (thread). Often this can be blown out with compressed air when the presser foot lever is lifted in the up position. In some cases, soft drinks and other sticky or corrosive liquids can find their way between the disks. In this case, the tension assembly must be removed, disassembled, and the disks cleaned and polished.
3. Check the facial surfaces of the bobbin case for corrosion, and sticky substances that prevents the thread from easily sliding over the bobbin case.
4. Check that the spindle of the hook body is not bent or warped, causing the bobbin case to wobble, thus creating an intermittent pressure on the hook race cover at the moment that the thread is trying to escape over the bobbin case finger. (Replace the hook body)
5. Inspect the undercut on the hook body spindle for thread wrappings and knots. This condition can cause the bobbin case to press hard against the hook race cover, hence hindered thread escapement .
6. Exceedingly tight bottom tension can cause some problems as well. ( If you don't know how to adjust Bernina bobbin cases to factory settings, please ask).
7. Hook timing, (loop lift) can be out enough to affect thread escapement. This is typical of newer machines made after 1986 since Bernina no longer made fixed timed machines like the earlier Swiss made models. The later made models have timing components that can slip under stressed machine mechanics.
SewTechnical Home ">
Feb 13, 2014 | Bernina 1008
I used the embroidery bobbin sewing and now it's not functioning
I do not believe the bobbin thread is the reason for the problem.
Refer to your manual for maintenance, especially cleaning the bobbin area.
When you replace the bobbin case be sure the needle is in it's highest position and this will also set the shuttle in position to properly accept the case.
If the problem continues, then machine will need to go into the shop. If the timing needs to be adjusted, this is best done by a Bernina tech.
Apr 28, 2010 | Sewing Machines
I have a Bernina 340 Deco embroidery computer. I am having trouble (lots) with the thread looping on top of fabric.
Make sure the bobbin case and shuttle are free from any thread tangles.
Thread with the presser foot up.
If problem persists, the machine will need to go into the shop where an authorized Bernina tech can check the timing and do a general service of the machine.
Take a sample of the mis-stitching.
Mar 20, 2010 | Sewing Machines
Sewing Machines Logo
530 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
