Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Replace bissell model 3760-5 cleaner belt - Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
5 Related Answers
Anonymous
SOURCE: bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Posted on Nov 10, 2007
Anonymous
  • 1673 Answers
SOURCE: Bissell Proheat Carpet Cleaner
First remove the some cover on the lfet side that is on top, then turn unit over, remove the red lock plate, has 1 screw, pull it out, then you can pull the end cap out, remove it, the cogged belt is there. If while you have the brush roll off, the pump belt can be replaced also. REmove old belt, put new belt over the bigger round part of the pump pully, feed it thru opening, then from the top, grap it and stretch it over the motor shaft. Then put the cogged belt on and reinstall the brush roll and the red lock.
Posted on Jan 31, 2008
Anonymous
SOURCE: Bissell Lift Off Broken Belt and Brush Roller
I had the same problem. I found that the brush actually melted to the end cap (the one with the square/ovalish end). I was able to pull it off with some force and applied some WD-40, but that only worked for one more use. The brush has again melted to the end cap and it is too deformed to try and fix. I suppose I will have to search for a new brush, but this model obviously has some innate flaws.
Posted on Dec 06, 2008
runnoft
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
BissellCSR
BISSELLcsr
  • 276 Answers
SOURCE: how can i replace the belt of bissell vaccum
Click HERE for BISSELL belt change video.
Posted on Jun 24, 2010
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
Need a new belt for a bissell lift off revolution turbo
Hi Dale, sorry to hear the belt has broken. Now is a good time to order filters for orders that are $30 or more receive free shipping. Here's a quick link to ordering one.
http://www.bissell.com/parts/?sc=search2&searchtext=3760
Jan 26, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Brush won't turn bissell vacuum 3760-4
No there is no separate fuse, when you did this you caused the drive motor to overheat, this destroyed the belt as you have seen and likely burned out the motor for the brush head..
Dec 06, 2011 | Bissell Vacuums
I've changed the belt on my Bissell 3760-2 model but the brush still doesn't rotate. I've checked for clogs and there are none.
Clogs affect the air movement, but not the brush assembly. Remove the brush assembly from the vacuum base. Remove, clean, and lightly oil (with 3-1 or similar) the two end bearings. They are usually choked with debris to the point that they lock the brush roller. Reassemble it without the belt for a moment and check for free turning. If ok, install the belt and test the whole vacuum. Hope this helps!
Jan 29, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
Model #3760-2 Bissell upright vacuum- making very loud noise when running. Cleaned all filters- no difference
Is the noise coming from the belt area, ie. beater bar, or does it sound like it is coming from the motor itself? It is possible there is something caught in the brush roller.
When you turn the roller off, does the noise go away?
Dec 20, 2010 | Bissell Vacuums
I bought a Bisell Pro-heat carpet shampooer and had the belt break after one use. Tried to buy replacement belts only to discover that store out of stock. Question: Is there such a thing as a "generic" or...
No unfortunately not. Some brands of vacuums and steam cleaners have similar belts that can be used on several different models, however this Bissell carpet cleaner has a very unique belt, that is really unlike any other belt on the market today.
I'm sorry to hear that your local store was out of stock on these. We do however have these belts in stock ready to ship today if you haven't already found them. We do offer free shipping & no tax (except VA). Here's a link to the brush belt for your Bissell:
http://www.govacuum.com/bissell-proheat-steam-cleaner-replacement-belt-part-0150621.html
Please feel free to add a comment if you'd like help installing the belt, I'd be more then happy to walk you through this.
If you found this helpful, it would be greatly appreciated if you rated the repair helpful, or left feedback.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have a 3760 lift off bissell. Replace the torn
Did you get the right belt size? The belt you should have bought is this one:
Bissell 3760 Belt
Nov 08, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Replacement wheel
The rear number is 2036627, there is no side casing, you would have to replace the whole back, which Bissell isn't making avaiable. But o get the wheel, you might try bissell.com and see if you can order direct, or try a local repair shop to see if they will order it for you.
May 06, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
Top Bissell Vacuums Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
