Yes, download your songs onto your pc then open pc suite, locate them in the panel on the left click copy then past in the music folder on your phone
SOURCE: unable to connect LG Viewty to PC via USB
Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
And Welcome to the Viewty Family! Enjoy...!
SOURCE: Can't use pc suite for lg Viewty using Vista
its easy all you have to do is copy music on to ur music file if u dont av it download shortkey lite n it will work
SOURCE: Cannot connect my LG Viewty to the computer via the LG PC suite
hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
SOURCE: When I connect my LG Viewty to my PC it doesn't show up
Do you have a memry card? If so then you can access that by going into settings, phone settings, connectivity, usb connection, andchanging it to mass storage.
