It sounds like the pressure rises too high.
Did you set the pressure correctly? Does it unload at the right pressure?
If not, there's a problem with the load/unload system and the inlet valve stays open
call IR for more help
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it releasemanually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
listen to rotation, periodically/quickly open the lid while in rotation, make take a few attempts. i had this problem and powered it off after i "faked" the printer into doing what i needed, goodluck
pump stuck with the lint just tille the washer open 5 or 6 screws on the pump clean the lint wrap around the wheel pump it will fix the problem good luck.this machine is a lemon get sue by some other state the company make it already lost the case why they still sell in cali
The safety switch that the lid engages when you close the lid is bad, it won't spin but will wash fine.Next your pump could have a clog which you should clear, third your external drain could be clogged. Try these sites for spares: RepairClinic.com espares.co.uk AppliancePartsPros.com mcminone.com
If there's
a loud thumping noise during the spin cycle, the load of clothes has
probably gotten unbalanced. Open the lid, redistribute the clothes in
the washer, then re-start it. Repeat these steps if necessary.
