My (Rheem)electrical heater is not heating the
My (Rheem)electrical furnace is not heating the house. The blower will come on but that is all.
Posted by tbryant8 on
  • tbryant8 Apr 06, 2009
    could you be more specific? I had no idea what you meant. I saw no small button
Donni Steen
  • 687 Answers
Check all your manual reset limits. There are two wires that go to a small disk about the size of a penny. In between those wires is a small button. Press the button firmly. You will have between 2 to 5 of these. There is also a limit switch located on the back wall of the unit that enters in the heat exchanger but it is not resetable that could be bad. You will need to check all of these. They can be jumped temporarily by removing the wires and adding a small wire.
Posted on Apr 06, 2009
  • Donni Steen Apr 06, 2009
    Sorry, I had my mind on a gas unit and not on the electric! My fault! Ok, do you have any fuses on this unit? Do you have any breakers just on the heat side of the air handler? If you answered yes, then check to make sure they aren't blown or tripped. If you answered no, then check to make sure the tstat is calling for it to come on. If it isn't replace the stat, if it is then check the sequencer. The sequencer will cause this to happen. Also, you didn't state that the A/C comes on. You might want to varify that it is coming on too. Again, accept my apology on the one track mind! There have been lots of gas furnace questions the last couple of days!
Where is the filter on a rheem corsair furnace?
I'm not familiar with the Rheem Corsair gas furnace, but the filter will be somewhere, filtering the return air. Is the furnace installed as an upflow, down flow or horizontal? Locate the blower door, open it up then work your way back on the duct that is returning air to the blower. Sometimes homes will have a filter return grill in a hallway ceiling. The grill has a couple nuts that can be removed, the grill swings down and houses the filter.
Feb 05, 2018 | Heating & Cooling
Heater blower won't start and we get o heat! What is going on with this Rheem REAA-080c
Earl, is this a furnace heater for your house? And are you referring to the blower that distributes the heat throughout the house? And does this unit have a flame exhaust blower? This last blower is a small blower in the unit itself, if it has one you usually can spot it.
Dec 08, 2016 | Rheem Water Heaters
When turn on my fire place heater heats for about 5 sec. Then a little white light flash's it turns the in heat colls off blower never turns on
How to Fix a Gas Furnace: Furnace Blower Does Not Turn ...
? 2:51
https://www.youtube.com/watch?v=XjgLbLYsuHw
Jan 18, 2012 - Uploaded by About.com
If the blower in your gas furnace won't turn off, it can cause major problems with your home heating system ...
Electric furnace blower motor doesn't turn on once in a while ...
terrylove.com > Forums > HVAC Heating & Cooling
Mar 7, 2014 - 16 posts - ‎5 authors Hi everyone, I'm having a problem with my Broan Electric furnace lately. Sometimes the blower motor doesn't want to switch on. Sometimes it ...
Oct 24, 2015 | Heating & Cooling
20 year old Rheem 90 plus 120k btu furnace blower runs contantly. Furnace and AC work fine (start and stop according to thermostat setting). What is problem? How fix?
Check to see if your unit has a heat sequencer. This is usually the problem with most furnaces. If it is bad, it will make the fan blower run all of the time. If you are not a electrican, you may want to get a electricin to look at it.
Dec 01, 2010 | Heating & Cooling
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Dec 23, 2009 | Honeywell Electronic Programmable...
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Rheem gas furnace blower unit not working properly
look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Sep 29, 2009 | Heating & Cooling
1970's Rheem electric furnace
no the older rheems had a sequencer for the heat that turned on the blower at the same time that the heat strios are energized. so the first thing that you need to do is figure out the sequencer that is keeping the fan running and get it replaced.
Jan 30, 2009 | Honeywell CT3200 5-2 Day Electronic...
Furnace filter is black and sooty wall seem to be sooty
   By sealed unit you mean that the burner air comes from outside of the house?      You have checked the heat exchanger for cracks by removing the burners and looking with a mirror and flashlight, correct, or had a service tech so?
The furnace burners have enough air and are burning clean (blue) with just a tip of orange at the end? You bought the house new and the fireplace has never been used?  If it has been used to clean smoke for the house for whatwever reason I woudl start by havign the ducts cleaned.   Another possibility I have seen is insolation inside of ductwork breaking down.
Jan 28, 2009 | RTO Home Heating Products 5.5HH240...
Heating & Cooling Logo
202 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
