KitchenAid KUDC25CH Dishwasher Logo
Anonymous Posted on Aug 13, 2013
Kitchenaid dishwasher control panel stuck - KitchenAid KUDC25CH Dishwasher
3 Related Answers
A
Anonymous
  • Posted on Sep 22, 2007
SOURCE: KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Anonymous
  • 3361 Answers
  • Posted on Jun 08, 2009
SOURCE: why my dishwasher kitchenAid control panel does
If you have no lights at all, check the thermal fuse located inside the control panel If the thermal fuse is good, check the continuity in the door switch.
Anonymous
  • 37 Answers
  • Posted on Sep 01, 2009
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
KITCHENAID DISHWASHER STUCK IN WASH CYCLE
It can be the issue with defective float switch. The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. One more thing, if your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Kitchenaid diswasher replaced control panel and dishwasher is not working again
Check the door switch, it could be a loose wire or broken door latch switch.
Start button not activating my kitchenaid sculptura dishwasher
Yes the control panel (also called switch panel) can be replaced.
Refer this site for details. You are probably referring to item 3 in the diagram.
Diswasher control panel not working.
Micro controller to be checked. Refer user guide and contact the service provider.
I have a Kitchenaid dishwasher model#KUDS01J, Icann't get it to start the rinse only cycle is stuck with a light blinkin and we cann't press any other functions on the panel.
I suggest having a qualified service tech diagnose your situation. The most likely issue would be a shorted touchpad. However, a failed control board could give you the same scenario. Both parts are expensive, so you would want to know which is failed prior to changing a part.
1helpful
WATER FROM MAIN WILL NOT SHUT OFF AND THE DISHWASHER OVERFLOWS
check flood control switch....the float that is under the bottom rack remove bottom panel to find switch also check inlet valve is not stuck.
Kitchenaid dishwasher KUDS01....
the pump is stuck. remove motor.insert plastic pen into bottom of motor.remove impeller by turning counter clockwise.file bottom of impeller stem.put enough washers on the keeper clip to prevent the impeller and the pump housing from binding.reassemble and there you have it!!!!
2helpful
KitchenAid Dishwasher
Nick,
It sounds like you have tried all the normal things for this. It is possible that you have a stuck key on the panel. Try pressing all the buttons several times to see if they may be stuck. It may just pop it loose. If that does not work you may need to try kicking the breaker off overnight. If that does not work you may need the electronic control. Lots of luck to you. Mike
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
