Question about Stanley Garden
The stanley garage door opener Model 3220.51 is about 20 years old. Although there is nothing at the bottom of the door, the door senses that there is something and the door comes back up on its own. The lights flash. This does not hapen all the time. The door may also open on its own after bieing down for a minute. I cannot find the manaul and ineed to know how to adjust the unit so the door will stay closed.
Posted by Kathy Jankovic on
Dave Vuckovich
    Sergeant:
  • 458 Answers
If it is a screw drive like mine all I needed to do was lube up the screw with a product called "fluid film" and all was ok. The screw was binding making the sensor think the door was blocked and it would go back up.
Posted on Dec 23, 2013
5 Related Answers
Mike
  • 4369 Answers
SOURCE: I've got an old wickes
You can also get remote units that connect to the same terminals that you would hard wire a button to. You really do want a later remote, as they all now use rolling code technology. Essentially you have to "invite" a remote and the unit and remote agree on a code. From that time on, the code changes every time that you use the remote (automatically, you do nothing). Way better security, and a guy cannot just run a frequency generator and open your door.
Posted on Sep 18, 2010
Mike
  • 4369 Answers
SOURCE: i have a stanley garage
The most important thing is to understand that the door spring can KILL YOU. If you are not absolutely certain that you know what you are doing, call a garage door guy. Many poeple get SERIOUSLY hurt.
So, you need two perfectly fitting rods to fit into the spring tightening end of the spring..
Release all spring tension. Release the opener.
Level the door with shims if necessary.
Install the first cable and turn the spring main rod to hold tension.
Put a vice grip on the main rod to keep it from unwinding any more
Release the 2nd cable spool and thread the other side cable. Turn the spool to have the same tension as the other cable.
Then wind the spring about 6 revolutions. (35 flats or tool insertions).
Verfiy the cable is still threaded correctly on both sides.
Correct spring tesnion is when the door will stay at 1/2 closed.
REconnect the opener and good to go.
Posted on Nov 10, 2010
HomePlicity
Jeff Bonvallet
  • 41 Answers
SOURCE: I have a stanley garage
Make sure the counter balance springs are ok. Most garage doors have 2 springs to provide counter balance for the door. Your garge door opener may have enough power to still operate even with one springs broken however with one springs broken would hit pretty hard. It the springs look ok I would release the door from the opener (while in the down position) using the little rope that hangs down and operate the door by hand to ensure it goes up and down smoothly. Most problems are due to friction caused by bad rollers or failed springs. If this is not the issue let me know.
Hope this helps
Posted on Nov 15, 2010
marc92
  • 11 Answers
SOURCE: HELLO, IS THERE ANYWHERE TO
http://www.garagedooropenerguide.com/stanley.html
Not great info, but there are links to email the remnants of the Stanley Garage Door company (the companies using the Stanley name went bankrupt), as well as some links for parts.
There is also this link for Stanley Garage Door manuals from the page above: http://www.aaaremotes.com/stowma.html
Posted on Feb 28, 2011
emissionwiz
Marvin
  • 85239 Answers
SOURCE: garage door opens only part
Hi
This may be just a matter of adjusting the safety limit switch rheostat at the rear of the opener motor. Here is the full set of instructions for proper adjustment.
Adjust garage door opener when your door is not working properly. There are certain components of your garage door opener that need adjusting to ensure that your door functions safely.
Things on Your Garage Door Opener That Need Adjustment
  • Limit
  • Force
  • Safety reverse
Step 1-How to the Limit
Turn the adjustment screw on the limit clockwise if the door doesn't fully close.
To open the door completely, adjust garage door opener by turning the limit counterclockwise.
Step 2-How to Adjust Garage Door Opener Force
If your door doesn't rise at least five feet when it is suppose to be opening, hold the bottom of the garage door while it is lowering. This will adjust the open force. For a door that doesn't reverse while closing hold the door as it opens to adjust the down force.
Step 3-Adjust the Safety Reverse
Use a piece of wood to stop and reverse the door, if the door doesn't reverse increase the down limit with a clockwise, one quarter turn.
Posted on Jun 16, 2011
Stanley garage door opener model 440. need a manual
Try Googling (Stanley)(440)(manual) without parens.
Apr 02, 2018 | Building Materials
The lights on my Stanley Model 810 Garage door opener do not work
replace the light bulbs or most people put cfl's in and the base of those bulbs are too big and the bulb actually doesnt contact the bottom of socket. try some old school bulbs. or just clean terminal bottom of socket. UNPLUG MACHINE FIRST OR YOU WILL TASTE PENNIES!!
Dec 02, 2013 | Building Materials
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't work. Motor housing turns partial revolution but looks like transmission jammed. Motor broke from mounting screws. Stanley Premier, came with house, maybe 25 years old. Time for...
THE OLD STANLEY UNITS ARE NOT WORTH FIXING.
PARTS ARE NOT AVAILABLE AND THE UNIT DOES NOT MEET THE SAFETY STANDARDS
TIME TO BUY A NEW CHAMBERLAIN / LIFTMASTER / OR CRAFTSMAN OPENER
GOOD LUCK
May 23, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
STANLEY GARAGE DOOR OPENER mODEL#9105 OPENS WHEN NOTHING IS UNDER
Stanley has been out of the garage door opener business for over 15 years. I reccommend replacing these openers when they start acting up because it is so difficult to get any parts. There is a reason that they went out of business.
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens by itself
Sounds like the Logig board is going bad in your unit.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
2,418 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
