I HAVE A CASSETTE TAPE DUAL HEAD COPY MACHINE.
THE #1 TAPE DECK WORKS PROPERLY, BUT #2 HEAD WILL COPY PROPERLY BUT WILL SLOWLY REWIND OR SOMETIMES NOT REWIND AT ALL. THE ONLY DATE I CAN FIND ON THE MACHINE IS 1987. IS THERE A REPAIR SHOP WHERE I COULD SEND THE MACHINE FOR REPAIR AND CLEANING?
CATALOG # 96250000
SER# 42504
SOURCE: telex copyette 1-2-3 you can hear both sides at the same time
Clean the heads, oil the spindles.
Basic problem is the tape alignment is off a little. Could be caused by too much tape tension causing it to wander.
Hope Ya Fix It. So ya can spread the word!
SOURCE: Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
SOURCE: Cassette door won't open
IF it is a deck with " soft touch " controls, that is, you arent using the old press hard down " piano key" style, but NOT a pure touch switch activation, then chances are either the drive belt has slipped, the belt broke, or the motor died. If this is the case ( soft touch = yes ), then unplug the unit, pop the cover off. You should be able to see the mechanism. When you view the mechanism from the front ( the side you normally see when using the deck ), the shiny little silver post that pulls the tape through during normal play will turn counter colckwise ( the shiny post runs against a rubber wheel ( the pinch roller )). What you should try is , with the unit unplugged and the cover off, if you can get your fingers to the deck in question, find the flywheel, should be a larger disk with a belt around it. Carefully spin the flywheel with your finger so that it turns counter clockwise, if you were looking from the front of the unit. This should cycle the deck through its cycle until you hear a click. Try to open the door. If the door doesnt open, press the stop button WHILE turning the flywheel again. This should drop the head assy and disengage the door lock mechanism. Remember, make sure the deck is unplugged, and BE GENTLE. you may feel a little resistance as you turn the flywheel. A little is OK, just be careful. If the flywheel comes to a hard stop when you are turning it, then something is jammed and you need to take it to a repair shop. Good luck...Rob. In the future, please specify a make and model so we can better help you . Thanks !!!
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
SOURCE: Telex Copyette 1-2-3: Master well wraps tape around the capstan.
Tape wrapping on a capstan shaft is commonly due to a sticky pinch roller or capstan shaft but is also because the take-up reel table does not provide enough torque or tension to gather up the tape. The Teac MTT160 cassette is a test tool we use to determine what the deck is doing torque wise. Telex probably has something similar. I worked with a guy who worked at Telex in the tape business- He did not talk about them much but he did say they had a lot of belts in them. Maybe you are just dealing with a belt that needs to be replaced. Lubrication also tends to be needed at every rotation point as well. That would include reel tables. I hope this gives you some help as Telex repairmen are getting to be like Hens teeth.
