First it was showing E40 got advice off the net,saying it could be door interlock or PCB bought a new lock as this was the cheeper option.just fitted this thought it had solved the problem as it started filling with water , but stopped working after a seconds and is now showing E70. I emptied it manually try it again but the same thing happened please help me if you can thanks
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame at approx 3 o clock pos,where the door striker pin goes through hole.
Held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
Check the Door Switch/interlock or the WIRING for failure in this case and repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
